Battery Ground Stud, Where to buy? |
bbrock |
Feb 10 2018, 07:23 PM
[Edit: This "mystery" has been solved. The correct answer was - I'm a dumbass]
I've spent countless hours in my engine bay rebuilding the hell hole. It just now hit me that I'm missing the ground stud for the battery. Is it M8x1.25 like the harness ground stud above? Would my FLAPS have them? Have only found lots of 75 or more on evil bay. I just need the one. (IMG:style_emoticons/default/smile.gif) |
tazz9924 |
Feb 10 2018, 07:41 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
If your not worried about originality autozone sells them
ejm |
Feb 10 2018, 07:51 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
There is no harness ground stud near the battery. The stud in the pic is the one for the battery ground cable.
bbrock |
Feb 10 2018, 07:57 PM
There is no harness ground stud near the battery. The stud in the pic is the one for the battery ground cable. Oh yeah! You're right (need emogi for slap self in head). So what's the little hole above the batter tray? Looks like something is supposed to be there. (IMG:style_emoticons/default/confused24.gif) |
Spoke |
Feb 10 2018, 08:06 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I just welded a bolt from my local hardware store in this position. I don't think getting a battery ground stud matters as long as you get the right size bolt.
forrestkhaag |
Feb 10 2018, 08:16 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
As fr as harness ground verses battery ground.... Ground is ground. If originally is not an issue simply tig weld a metric bolt threads out to the body in generally correct location.
As for needing to slap yourself around for not enunciating or clarifying the different grounds. Don't. There are plenty of slap people on World that remind us daily of our inaccuracies in a simple question. Keep asking. (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
bbrock |
Feb 10 2018, 10:35 PM
Thanks guys. More dumb questions to follow. (IMG:style_emoticons/default/beerchug.gif)
JeffBowlsby |
Feb 10 2018, 10:44 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The battery ground stud is in your picture...you know that right?
bbrock |
Feb 10 2018, 10:47 PM
The battery ground stud is in your picture...you know that right? Yep, ejm pointed it out and as soon as I saw his post, the light bulb went off that the harness ground is on the other side. There's still that little depresion above the battery tray that looks like it was intended for a stud that puzzles me. But I see there is a similar one on the other side. I'll go back to ignoring it. |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:32 AM |
