Sold: Pair OEM Hella TN4 Driving Lamps, Driver Quality |
914_7T3 |
Feb 23 2018, 12:22 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Picked these up from a respected World Member and swapped out one reflector that was in better condition than mine. However, I added a cleaner set of TN4 lenses as one was broken. One of the rings is dinged and some corrosion is present in one of the housings although not noticeable once reassembled.
The only thing you will need is a replacement set of seals for the lenses and 914 Rubber has got those available with the protective lens protectors. Clean them up and run as is for a good driver quality set or powder coat & pick up a spankin' new set of lenses from 914 Rubber and restore to new. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/first.gif) Price is $85.00 plus applicable shipping or local pick up in SoCal. |
edrotol |
Feb 23 2018, 07:28 PM
edrotol Group: Members Posts: 190 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States |
Picked these up from a respected World Member and swapped out one reflector that was in better condition than mine. However, I added a cleaner set of TN4 lenses as one was broken. One of the rings is dinged and some corrosion is present in one of the housings although not noticeable once reassembled. The only thing you will need is a replacement set of seals for the lenses and 914 Rubber has got those available with the protective lens protectors. Clean them up and run as is for a good driver quality set or powder coat & pick up a spankin' new set of lenses from 914 Rubber and restore to new. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/first.gif) Price is $85.00 plus applicable shipping or local pick up in SoCal. PM sent |
914_7T3 |
Feb 23 2018, 08:08 PM
Sold.....
Lo-Fi Version | Time is now: 8th June 2024 - 08:44 PM |
