FS: 1972 1.8 engine and transmission, $500 |
Ben and Ralph |
Feb 25 2018, 11:46 PM
Ben Group: Members Posts: 110 Joined: 8-July 10 From: Los Angeles Member No.: 11,917 Region Association: Southern California |
Just pulled this engine out of my 914. I have no paperwork on it but it was rebuilt before being put in the car and I have been driving it for approximately four years. If I had to guess it has less then 25,000 miles on it.
The engine started off as a 1.7 but was built to a 1.8 when rebuilt. Ran a compression test and all four cylinders are reading 130. The engine has dual solex 40 single barrel carbs. Transmission is a tailshift which is in good running condition, was also rebuilt before being but it in four years ago. Unfortunately no paperwork. Asking $500 for the engine, local pick up only from Los Angeles County Area. Transmission is negotiable. The car was running and driving on the freeway this morning with both engine and trans. |
Krieger |
Feb 26 2018, 08:38 AM
Advanced Member Group: Members Posts: 4,726 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Dang good deal!
porschetub |
Feb 26 2018, 01:15 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Wonder if those carbs were on the motor from new? if so it will be a European spec,I remember seeing one of those in a shipment of parts a guy had imported from Europe when he moved here to live.
914_teener |
Feb 26 2018, 02:03 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Just pulled this engine out of my 914. I have no paperwork on it but it was rebuilt before being put in the car and I have been driving it for approximately four years. If I had to guess it has less then 25,000 miles on it. The engine started off as a 1.7 but was built to a 1.8 when rebuilt. Ran a compression test and all four cylinders are reading 130. The engine has dual solex 40 single barrel carbs. Transmission is a tailshift which is in good running condition, was also rebuilt before being but it in four years ago. Unfortunately no paperwork. Asking $500 for the engine, local pick up only from Los Angeles County Area. Transmission is negotiable. The car was running and driving on the freeway this morning with both engine and trans. Can you post a shot of the exhaust ports....? |
burton73 |
Feb 26 2018, 02:35 PM
burton73 Group: Members Posts: 3,541 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
PM sent.
Bob B |
David.laRuse |
Feb 27 2018, 11:00 AM
Newbie Group: Members Posts: 3 Joined: 3-February 15 From: Cedar Rapids Member No.: 18,397 Region Association: None |
I WILL GIVE YOU $500.00/CASH FOR THE ENGINE AND TRANS. AND PICK IT UP IN 5-7 DAYS. LET ME KNOW, DAVID. (IMG:style_emoticons/default/welcome.png)
Lo-Fi Version | Time is now: 6th June 2024 - 09:13 AM |
