Defrost vents |
Defrost vents |
pjhaun |
Mar 15 2018, 06:33 PM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
What year 914 had the center defrost vent? And how did it work or how was is hooked up?
Thank You!!!!! |
914work |
Mar 15 2018, 11:25 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Phil it was only on early cars. The drivers side vent (I believe) had a 1" or so dia outlet stubbed off it with a small paper/foil tube that connected to that vent.
I have a pic somewhere...ah found it! (IMG:style_emoticons/default/smile.gif) |
Mikey914 |
Mar 16 2018, 02:55 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yep on my 70 too
Tbrown4x4 |
Mar 16 2018, 04:53 AM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
My '71 has one.
maf914 |
Mar 16 2018, 06:50 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
According to the 914 Restorer's Guide the center vent was deleted on the 72 and later cars.
Attached image(s) |
pjhaun |
Mar 17 2018, 12:24 AM
According to the 914 Restorer's Guide the center vent was deleted on the 72 and later cars. I have a 1974 and it seems that the defrost does not defrost the windshield very well. It seems that it only defrost half the windshield and its not the half I need. I wonder if the earlier model 914 had the same problem with the center, left, and right vents. |
Steve |
Mar 17 2018, 01:09 AM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I always had better luck with cold air out the defrost vents and hot air down below.
It seems like the hot air just fogged the windshield up more. |
RangerDick |
Mar 17 2018, 09:23 PM
Newbie Group: Members Posts: 18 Joined: 15-May 17 From: Burlingame, CA Member No.: 21,104 Region Association: Northern California |
Not on my 73
Lo-Fi Version | Time is now: 2nd June 2024 - 10:04 AM |
