gauge help needed |
gauge help needed |
JFG |
Mar 22 2018, 01:03 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
Dave_Darling |
Mar 22 2018, 01:36 PM
Pretty sure what's missing there is a green/black wire. That should be in your wiring harness, at least to the center console area. (Assuming you're talking about the 74 in your sig.)
Not sure about which spades the wires go on, but if you look at the back of the gauge there should be symbols. Either "+" or "30" would get the power; "G" would get the sender, and three parallel lines would get the brown wire. --DD |
JFG |
Mar 22 2018, 02:52 PM
Thanks Dave I'll double check the symbols on the back of the gauge.
I have no green/black wire in the dashboard. The cable is in the engine bay so it looks like I'll have to add a wire to the gauge from wherever I find that green/black wire in the centre console. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:45 AM |
