914zim |
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 ![]() |
Fellas:
Is there a way to test the reverse light switch while it's removed from the car? I have everything taken apart for the clutch replacement and I was wondering if I need a new switch, because it's pretty banged up. Also, does anyone have a working used one laying around they'd sell me cheap? I'm finding it really hard to plunk down $80 for a new one! Thanks, Andy... |
elocke |
Member ![]() ![]() Group: Members Posts: 178 Joined: 9-February 03 From: Georgetown, MA Member No.: 272 ![]() |
Get a multimeter, ohm meter, beeper; anything that will tell you if you have an electrical connection. With the meter leads in the 2 contact receptacles on the switch, push a coat hanger end into the hole in the middle of the threads on the other side of the switch. This depresses a plunger that makes a connection inside the switch. If the switch is good you will get an indication of a connection, beep, needle deflection, etc. I have a switch from an early tranny that only makes contact at the very end of the plunger travel and didn't work with the pin in the tranny. I switched it with the switch from my '74 and it worked fine. To test the backup lights, unplug the 2 wires from the switch (make sure they don't touch any metal) turn the ignition on and touch the 2 wires together.
Good luck Ed |
914zim |
Cool, thanks Ed!!!
jr91472 |
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 ![]() |
never had one of those out of the tranny before.......is there a seal associated with it? Or can you just take em out?
sorry for the mild hijack |
elocke |
I've just taken mine out. There's a washer. When I removed tranny fluid didn't spill out.
Red-Beard |
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None ![]() ![]() |
If the tranny is full of oil, leave the pin in. It won't pour out, but it will drip/ooze a bit...
Lo-Fi Version | Time is now: 11th July 2025 - 02:08 PM |
