spot weld drill, Viking VT-8500 |
restore2seater |
Apr 21 2018, 05:53 PM
Future 914 copilot. Group: Members Posts: 311 Joined: 30-October 04 From: Dunlap,IL Member No.: 3,037 Region Association: None |
There is a FS on pelican for a spot weld drill. Has anyone ever used anything like this? If so, how well does it work?
Viking VT-8500 |
ConeDodger |
Apr 21 2018, 08:51 PM
Apex killer! Group: Members Posts: 23,605 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I just bought a spot weld drill bit at the Autobody supply store. $15? (IMG:style_emoticons/default/evilgrin.gif)
Steve |
Apr 21 2018, 09:55 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Be careful... pretty easy to drill a bigger hole removing the spot weld. I find it easier to just grind it off with a small grinder.
mb911 |
Apr 22 2018, 08:21 AM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Be careful... pretty easy to drill a bigger hole removing the spot weld. I find it easier to just grind it off with a small grinder. (IMG:style_emoticons/default/agree.gif) |
worn |
Apr 22 2018, 10:29 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Be careful... pretty easy to drill a bigger hole removing the spot weld. I find it easier to just grind it off with a small grinder. Often the rust powder is a sign that you have cut through the first layer. I like the one I got from Eastwood. Just a rotobroach type bit with a spring tip. I also use a 1/8 bit to make dents for the pilot to stay in. I think the tool in question is for those who do this every day. Glad I haven't had to do it in several years now. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:21 AM |
