WTB- GT Fuel Gauge |
crsedge |
Apr 27 2018, 03:57 PM
Newbie Group: Members Posts: 32 Joined: 25-March 12 From: Australia Member No.: 14,304 Region Association: None |
Hi All,
Looking for 60mm separate 914 GT Fuel Gauge. Anyone have one surplus to needs or any leads appreciated (IMG:style_emoticons/default/beerchug.gif) Cheers Craig Attached image(s) |
Steve |
Apr 27 2018, 04:13 PM
914 Guru Group: Members Posts: 5,614 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Check with Auto Atlanta. That’s where I got mine from many years ago.
crsedge |
Apr 27 2018, 05:44 PM
PancakePorsche |
Apr 27 2018, 11:05 PM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
North Hollywood Speedometer makes exact replicas.
crsedge |
Apr 28 2018, 02:41 AM
914Sixer |
Apr 28 2018, 07:03 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Craig,
I have a nos VDO fuel gauge that is needed for building the gauge. The stock console gauges are 60mm. Take the guts out and drill the 2nd light hole in. I have some used studs for bulbs from old gauges. Use the offf set rubber from the fuel light. Use the 60 mm dial face from the volt or temp gauge. Drill hole in face for low fuel light. Have face rescreened to match GT dial face. The only difference is there is no mounting studs on the back of case. Pretty sure NHS can do all this for you if you have a used console gauge and this nos gauge. Attached image(s) |
bdstone914 |
Apr 28 2018, 08:18 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What you picture looks like a 52mm VDO aftermarket gauge. You will need a compatible sending unit.
Readily available. https://www.google.com/search?q=vdo+fuel+ga...ent=firefox-b-1 |
Larmo63 |
Apr 28 2018, 08:52 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I've been after NH Speedometer for two years to make GT gas gauges.
Impossible, I've called him five times. |
914Sixer |
Apr 28 2018, 02:25 PM
Finding the parts is the hard part.
pete000 |
Apr 28 2018, 04:00 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
The GT gauge is 60mm same as the center gauges found on the 914 center console on the 2.0 cars. Another method is using a Saab fuel gauge and having the graphics redone. Only problem is they are getting really hard to find now.
crsedge |
Apr 28 2018, 10:25 PM
Craig, I have a nos VDO fuel gauge that is needed for building the gauge. The stock console gauges are 60mm. Take the guts out and drill the 2nd light hole in. I have some used studs for bulbs from old gauges. Use the offf set rubber from the fuel light. Use the 60 mm dial face from the volt or temp gauge. Drill hole in face for low fuel light. Have face rescreened to match GT dial face. The only difference is there is no mounting studs on the back of case. Pretty sure NHS can do all this for you if you have a used console gauge and this nos gauge. Thanks 914Sixer. I might pass on this one and aim to get one the correct 60mm size to start with. Cheers Craig |
type47fan |
Apr 30 2018, 12:25 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
Craig, I have a nos VDO fuel gauge that is needed for building the gauge. The stock console gauges are 60mm. Take the guts out and drill the 2nd light hole in. I have some used studs for bulbs from old gauges. Use the offf set rubber from the fuel light. Use the 60 mm dial face from the volt or temp gauge. Drill hole in face for low fuel light. Have face rescreened to match GT dial face. The only difference is there is no mounting studs on the back of case. Pretty sure NHS can do all this for you if you have a used console gauge and this nos gauge. Thanks 914Sixer. I might pass on this one and aim to get one the correct 60mm size to start with. Cheers Craig Here's a SAAB gauge and the first GT style gauge made for me by NHS in '05: Subsequently, I sent it back to them to change the graphics and add the longer needle. I sent them the last SAAB gauge I had and they returned two, long needle fuel gauges to me: This is one currently installed in my center console: As of this date I have one long needle gauge remaining. |
crsedge |
Apr 30 2018, 02:02 PM
Craig, I have a nos VDO fuel gauge that is needed for building the gauge. The stock console gauges are 60mm. Take the guts out and drill the 2nd light hole in. I have some used studs for bulbs from old gauges. Use the offf set rubber from the fuel light. Use the 60 mm dial face from the volt or temp gauge. Drill hole in face for low fuel light. Have face rescreened to match GT dial face. The only difference is there is no mounting studs on the back of case. Pretty sure NHS can do all this for you if you have a used console gauge and this nos gauge. Thanks 914Sixer. I might pass on this one and aim to get one the correct 60mm size to start with. Cheers Craig Here's a SAAB gauge and the first GT style gauge made for me by NHS in '05: Subsequently, I sent it back to them to add the longer needle: This is it currently installed in my center console: Thanks mate. Exactly what i need- presume it isn't for sale? (IMG:style_emoticons/default/biggrin.gif) |
Martin Baker |
Apr 30 2018, 02:14 PM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
I just had two of these Saab gauges converted by N Hollywood, it took six months and cost over $800 dollars. I have one I bought from Wayne, short needle version for sale. I will sell it for $350.00. It works perfect.
crsedge |
Apr 30 2018, 02:17 PM
Martin Baker |
Apr 30 2018, 02:22 PM
Here is an FYI for everyone with a SAAB gauge. The movement in the SAAB VDO is different than the PORSCHE VDO Type. SAAB uses a swinging float with a different OHM range. PORSCHE sender is a tube type float. So the 60 MM housing is correct. That is about it...except for the glass...
Lo-Fi Version | Time is now: 10th June 2024 - 07:15 AM |
