Any 914 horn button retrofit?, Rubber button is a pain - any alt retrofit? |
StarBear |
May 25 2018, 07:43 AM
Senior Member Group: Members Posts: 1,906 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
The rubber button and ring combination is really annoying - the button/horn keeps getting knocked out of alignment with road bumps and stuff, leaving the horn loose and not/barely working. Keep having to redo (or replace) button and wire. Any clever alternate fixes to this? Thanks!!!
bdstone914 |
May 25 2018, 08:30 AM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The rubber button and ring combination is really annoying - the button/horn keeps getting knocked out of alignment with road bumps and stuff, leaving the horn loose and not/barely working. Keep having to redo (or replace) button and wire. Any clever alternate fixes to this? Thanks!!! Buy a new one. https://www.pelicanparts.com/catalog/SuperC..._pg3.htm#item14 |
StarBear |
May 27 2018, 08:21 AM
Yeah, been doing that - replacing it every 3-4 years. Fortunately not a big ticket item, but thought a) everyone has these 914 typical problems and b) someone smart has figured out a more thoughtful workaround. Still trying to find that little female spade connector - mine broke off a dozen years ago and eyes just can't "thread" the wire into that little hole any more. :+(
914Sixer |
May 27 2018, 10:00 AM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Same old story, the new ones are not the same as the originals. Rubber compound is not the same.
Larmo63 |
May 27 2018, 11:00 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I run a hockey puck horn button, but I've never had any issues with the rubber cuff.
They do have to be very carefully installed, but no issues. |
McMark |
May 27 2018, 02:09 PM
The latches for your horn button may be bent, or the securing screws may be loose.
StarBear |
May 30 2018, 01:35 PM
Thanks all for your input. Worked with my long-time buddy Jerry Rigg to fashion a female spade connector (broke 20+ years ago) for the wire onto the male spade (can't see that tiny hole anymore) and added three #6 SS washers underneath the horn ring plate in the batwing to "move" the plate a bit closer to the base plate on the steering wheel. Also tightened screws (they WERE loose) and replaced the button with a new one, so now very tight and firm. (IMG:style_emoticons/default/biggrin.gif)
dr914@autoatlanta.com |
May 30 2018, 02:23 PM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the 73-76 horn base plate was always a problem as if the screws loosened and the horn boot was dried out, the wire would break off the tiny male spade made into the horn button. We finally made a new horn base plate to solve this broken spade problem, and Jorge at sierra madre makes an insulator kit that we too sell.
Thanks all for your input. Worked with my long-time buddy Jerry Rigg to fashion a female spade connector (broke 20+ years ago) for the wire onto the male spade (can't see that tiny hole anymore) and added three #6 SS washers underneath the horn ring plate in the batwing to "move" the plate a bit closer to the base plate on the steering wheel. Also tightened screws (they WERE loose) and replaced the button with a new one, so now very tight and firm. (IMG:style_emoticons/default/biggrin.gif) |
porschetub |
May 30 2018, 04:32 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
The engagement lugs can get bent and the batwing/hockey puck won't compress the rubber cuff fully.
The aftermarket ones seems to be a softer rubber than the genuine part or atleast that's what I found. |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:57 AM |
