| 914Sixer |
May 30 2018, 12:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,428 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
This is a side by side comparison for the SMP FJ67 and a Bosch 019. First up is the FJ67 nozzle tip is shorter. Second the FJ 67 has 3 spray heads, the Bosch has one. Original rubber O rings work fine, just like on the Bosch. Hose is shorter but not a real problem. The FJ67 has a different connector, hard to tell but the pins are more to the top of the plug and the whole frame is larger. I suspect the correct connector for this injector is the one used on the 1.8 Bosch. I am going to take the injector to the local parts store and see what will fit. This is going to require the injection wire harness to be modified.
Lastly I have not been able to find the specifications for the FJ67. Websites on say that it replaces the 2.0 injector. Attached image(s)
| 914_teener |
May 30 2018, 12:34 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Test it.
| 914Sixer |
May 30 2018, 01:09 PM
Going to keep the FJ 67 new.
| jcd914 |
May 30 2018, 11:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Not the 1.8 injector connector, looks to me like the standard 1.7 or 2.0 connectors should fit.
Jim |
| TheCabinetmaker |
May 31 2018, 09:42 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,365 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The shorter hose to the rail is a bonus.
| rjames |
Sep 25 2018, 01:24 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,438 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Not the 1.8 injector connector, looks to me like the standard 1.7 or 2.0 connectors should fit. Jim (IMG:style_emoticons/default/agree.gif) Any update on this? Does the FJ67 work as a suitable replacement for the original Bosch injector? |
Lo-Fi Version | Time is now: 3rd March 2026 - 01:05 AM |
