74/2.0 Clutch Adjustment |
vitaminc914 |
Jun 5 2018, 06:18 AM
Newbie Group: Members Posts: 30 Joined: 4-July 05 From: Allendale, MI Member No.: 4,374 Region Association: Upper MidWest |
I am getting a little grinding when I try to go into reverse. I think my clutch needs some adjusting. I tried to find a good tutorial on Youtube but no luck or I didn't search correctly. If anyone on here has a link to a good video or a pictorial, please send it my way. I have a Hanes manual, but I find videos to be easier for me to understand.
Thanks! |
bdstone914 |
Jun 5 2018, 06:49 AM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
How much free play is in the pedal? Should be no more than 1 inch. Does not sound like an adjustment. If you wait a few seconds after depressing the pedal to shift to reverse does it still make the grinding sound ?
Tighten the two nuts on the clutch cable a the transmission until excess free play is removed. |
vitaminc914 |
Jun 5 2018, 12:48 PM
There is about an inch of free play and I don't remember ever having any free play in the past. It does make the sound even after waiting a few seconds with the clutch pedal depressed. I will take a look at the nuts on the clutch cable.
How much free play is in the pedal? Should be no more than 1 inch. Does not sound like an adjustment. If you wait a few seconds after depressing the pedal to shift to reverse does it still make the grinding sound ? Tighten the two nuts on the clutch cable a the transmission until excess free play is removed. |
euro911 |
Jun 5 2018, 01:12 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Long, cheesy video, but skip close to the end to see the adjustment
https://www.youtube.com/watch?v=/vlniyILtRMM |
vitaminc914 |
Jun 5 2018, 07:01 PM
I was able to get it fixed. I just turned the 11mm nut inward towards the rear of the car about 1/4 inch and that did it. Shifting perfectly again.
Long, cheesy video, but skip close to the end to see the adjustment https://www.youtube.com/watch?v=/vlniyILtRMM |
euro911 |
Jun 5 2018, 08:14 PM
I was able to get it fixed. I just turned the 11mm nut inward towards the rear of the car about 1/4 inch and that did it. Shifting perfectly again. 11mm nut (should be two 11mm nutS) ... the second nut locks up against the first one to help assure it doesn't inadvertently come loose.If you find it necessary to adjust the cable often, it's a sign that it just might be time for a whole new cable (IMG:style_emoticons/default/idea.gif) |
Dr Evil |
Jun 6 2018, 08:31 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Click in my sig below for my 31 pages of notes. I have instructions, work up, and diagrams to help with this.
Lo-Fi Version | Time is now: 2nd June 2024 - 07:03 PM |
