mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
2 pair 911 - 3.5” Boge front struts for sale The first pair I think is from an SC. They are in very good condition and inserts seem to be fine but are sold - as is.
The second pair is probably from a Carrera since it has the bracket for the brake sensor. You don’t need the sensor to use these struts. Inserts are functional but - as is. There should be no functional difference between either pair. I don’t know if the Carrera inserts are valves for a slightly heavier car. Both pairs will accept Billstein strut inserts (made for Boge struts) , the inserts usually come with both types of top caps, internal and external. Both pairs will only accept calipers with 3.5” spacing or need adaptors to use other calipers like Boxster brakes. $450 + ship (usually around $50 xcountry) Email - mark@markepstein.net to purchase Attached image(s) ![]() ![]() |
flmont |
Senior Member ![]() ![]() ![]() Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region ![]() ![]() |
what does the 3.5" spacing have to do with the 5 lug conversion,is that for a specific type of rim and rotor ?? (IMG:style_emoticons/default/confused24.gif) Thanks Frank
mepstein |
what does the 3.5" spacing have to do with the 5 lug conversion,is that for a specific type of rim and rotor ?? (IMG:style_emoticons/default/confused24.gif) Thanks Frank It determines which front brake caliper you can use. |
flmont |
Ok,..and which one's will I use,..LOL..I honestly don't know how to piece it together I think I would upgrade to a 15 or 16 X 7 " rim with standard 911 calipers and drilled disc.
mepstein |
Ok,..and which one's will I use,..LOL..I honestly don't know how to piece it together I think I would upgrade to a 15 or 16 X 7 " rim with standard 911 calipers and drilled disc. 15" and larger can be used on almost any size brake caliper as long as they are real Fuchs. Some fake Fuchs can have fitment issues. |
flmont |
in reality it would be easy to do a 5 lug upgrade with your SC strut's on a 76' 914 and I assume calipers and rotors are easy to get, as well,..
mepstein |
in reality it would be easy to do a 5 lug upgrade with your SC strut's on a 76' 914 and I assume calipers and rotors are easy to get, as well,.. Yes. Calipers are easy to pick up for very reasonable prices on pelican and rotors are available from autozone, ect or amazon, ect. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,542 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Ok,..and which one's will I use,..LOL..I honestly don't know how to piece it together I think I would upgrade to a 15 or 16 X 7 " rim with standard 911 calipers and drilled disc. Read up my friend. http://www.914world.com/bbs2/index.php?sho...p;hl=conversion |
flmont |
thanks Bdstone
mepstein |
Pending
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
mepstein |
One pair still for sale.
eatpez |
Newbie ![]() Group: Members Posts: 18 Joined: 4-October 18 From: Michigan Member No.: 22,543 Region Association: North East States ![]() |
Interested if still available.
mepstein |
Sold a while ago
Lo-Fi Version | Time is now: 17th June 2024 - 04:23 AM |
