| bodocean |
Jun 11 2018, 10:17 AM
Newbie ![]() Group: Members Posts: 3 Joined: 10-June 18 From: Rockford IL Member No.: 22,212 Region Association: North East States |
I recently got my 914. Feels like it was a barn find, so it came with disconnected fuel lines and no brakes mounted. All the parts where in the frunk and trunk.
I tried fitting the front brakes but i didn't get it working, because the brakes doesn't fit. The seller told me they were 914 brakes and should fit perfectly but the more i research the more i think they are the BMW E21 320i brakes. I hope you guys can help me identifying what brake calipers I have. If they are the E21 ones i'll add the dimensions and what has to be done to it to make them fit to your 914 Thanks for your help guys! here the Pictures: (IMG:http://www.914world.com/bbs2/uploads_offsite/preview.ibb.co-22212-1528733853.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/preview.ibb.co-22212-1528733854.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/preview.ibb.co-22212-1528733855.3.jpg) |
| Mblizzard |
Jun 11 2018, 02:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Quick question.. Are these the brakes you want on the car? Unless you have a specific reason for using these I would get the stock brakes from PMB and not risk the retro fit process unless there is a good reason and you have the skills to complete.
PMB is not cheap but it is a one and done approach. |
| bodocean |
Jun 11 2018, 02:28 PM
PMB is not cheap but it is a one and done approach. The only reason I wanted to fit them on the car was because they came with the car. (were never mounted though) I thought the previous owner seemed like he knew what he was doing. E21 or Stock Brakes? I do have a Shop, who can machine it for me so this is not a problem. I couldn't find 914 calipers under 350$ (i don't have a core) but i found cheaper E21s |
| Mblizzard |
Jun 11 2018, 03:06 PM
Look for member Eric Shea and PM him to ask him what modifications are required.
True the stock units are not cheap but they are hard to beat. |
| bodocean |
Jun 11 2018, 03:11 PM
| burton73 |
Jun 11 2018, 03:13 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,984 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
Hi welcome to the world. Lots of great people here to help you and most will try to swing you a deal. Lots of guys change out so them may be able to help you out. Great advice delivered here most of the time and guys are trying to help fellow 914 bros.
Bob B (IMG:style_emoticons/default/welcome.png) |
| BENBRO02 |
Sep 1 2019, 07:33 PM
Member ![]() ![]() Group: Members Posts: 485 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region
Did anyone ever determine what your calipers were? I have what looks like the same calipers on my car. I bought all the late suspension parts except calipers and now the calipers won't fit. Okteenerfest is fast approaching and I don't have what I need. Yikes!
| bdstone914 |
Sep 1 2019, 07:47 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,271 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@BENBRO02
The ones pictured from the original poster are stock 914 calipers. Do you have no calipers or just bad ones ? I have early or late front cores if that is any use to you. Some might be usable. I would see if PMB can send out a restored pair to get you going. Bruce |
| BENBRO02 |
Sep 1 2019, 08:01 PM
@BENBRO02 The ones pictured from the original poster are stock 914 calipers. Do you have no calipers or just bad ones ? I have early or late front cores if that is any use to you. Some might be usable. I would see if PMB can send out a restored pair to get you going. Bruce My car had what I thought was an early suspension and late calipers. It had washers added between the early spindles and calipers, and spacers so the wheels wouldn't hit the calipers. It shimmies at highway speed because of the spacers. I bought all the late suspension parts from PMB but now the calipers I have won't fit. |
| BENBRO02 |
Sep 1 2019, 08:06 PM
| bdstone914 |
Sep 1 2019, 08:15 PM
@BENBRO02
Something is wrong. Any idea what? [/quote] Yes, You have late struts, looks like early calipers. Cant tell for sure on the calipers from that angle. Do the inlets use Banjo bolts 12mm or a direct 10mm line nut ? The change is a VIN 19032. I can see the taper pin in the bottom of the strut so the struts are late. Think you need a pair of late calipers to match to what you have. Bruce |
| BENBRO02 |
Sep 1 2019, 08:33 PM
[quote name='bdstone914' date='Sep 1 2019, 10:15 PM' post='2743313']
@BENBRO02 Something is wrong. Any idea what? [/quote] Yes, You have late struts, looks like early calipers. Cant tell for sure on the calipers from that angle. Do the inlets use Banjo bolts 12mm or a direct 10mm line nut ? The change is a VIN 19032. I can see the taper pin in the bottom of the strut so the struts are late. Think you need a pair of late calipers to match to what you have. Bruce [/quote] Attached thumbnail(s) |
| BENBRO02 |
Sep 1 2019, 08:37 PM
[quote name='BENBRO02' date='Sep 1 2019, 10:33 PM' post='2743314']
[quote name='bdstone914' date='Sep 1 2019, 10:15 PM' post='2743313'] @BENBRO02 Something is wrong. Any idea what? [/quote] Yes, You have late struts, looks like early calipers. Cant tell for sure on the calipers from that angle. Do the inlets use Banjo bolts 12mm or a direct 10mm line nut ? The change is a VIN 19032. I can see the taper pin in the bottom of the strut so the struts are late. Think you need a pair of late calipers to match to what you have. Bruce [/quote] [/quote] These were sold to me as late calipers (double bleeders) and they match what I had. |
| BENBRO02 |
Sep 1 2019, 08:39 PM
[quote name='BENBRO02' date='Sep 1 2019, 10:37 PM' post='2743315']
[quote name='BENBRO02' date='Sep 1 2019, 10:33 PM' post='2743314'] [quote name='bdstone914' date='Sep 1 2019, 10:15 PM' post='2743313'] @BENBRO02 Something is wrong. Any idea what? [/quote] Yes, You have late struts, looks like early calipers. Cant tell for sure on the calipers from that angle. Do the inlets use Banjo bolts 12mm or a direct 10mm line nut ? The change is a VIN 19032. I can see the taper pin in the bottom of the strut so the struts are late. Think you need a pair of late calipers to match to what you have. Bruce [/quote] [/quote] These were sold to me as late calipers (double bleeders) and they match what I had. [/quote] Also these calipers didn't fit correctly with the early suspension I had on the car so how could they be early calipers? |
| Gatornapper |
Sep 2 2019, 06:16 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,290 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States
Interesting. My 914 came with the same brakes on them. They work great. Apparently almost no mods are needed for them to fit - mounting bolt holes are the same. A small part of the pan needs to be bent away, that's all.
The outer half of my right caliper had a crack in the lip, could not find but one nasty caliper for $100 in whole country. Our hero Eric at PMB came to my aid - he had what I needed and sent it to me quickly. BTW, he rebuilds BMW brakes too and knew the caliper well. The brakes work fine. Rotors appear stock. I think the E21 brakes have a slightly larger surface area on the pistons. GN I recently got my 914. Feels like it was a barn find, so it came with disconnected fuel lines and no brakes mounted. All the parts where in the frunk and trunk. I tried fitting the front brakes but i didn't get it working, because the brakes doesn't fit. The seller told me they were 914 brakes and should fit perfectly but the more i research the more i think they are the BMW E21 320i brakes. I hope you guys can help me identifying what brake calipers I have. If they are the E21 ones i'll add the dimensions and what has to be done to it to make them fit to your 914 Thanks for your help guys! here the Pictures: |
Lo-Fi Version | Time is now: 17th March 2026 - 03:54 PM |
