Early Horn Ring Wiring, Okay, 2nd stupid question if anyone is keeping count |
db9146 |
Jun 23 2018, 03:26 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I pulled the horn ring off my '70 -6 and thought, "only two brown wires, one with a white stripe and one without. No problem remembering where they connect"....yea, right!
Okay, the brown wire with the white stripe has the female spade connector that slips on to the spade on the back of the horn ring. Which screw does the other solid brown wire with the grounding ring connect to? Does it go under one of the four screws that hold the clam shell on? |
worn |
Jun 23 2018, 03:51 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I pulled the horn ring off my '70 -6 and thought, "only two brown wires, one with a white stripe and one without. No problem remembering where they connect"....yea, right! Okay, the brown wire with the white stripe has the female spade connector that slips on to the spade on the back of the horn ring. Which screw does the other solid brown wire with the grounding ring connect to? Does it go under one of the four screws that hold the clam shell on? Generally solid brown goes to ground somewhere. But I am not at all familiar with an early six. |
Mike Bellis |
Jun 23 2018, 05:06 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Solid brown is ground. Brown/white is a switched ground. BTW, any wire with a white stripe is "switched"; either power or ground depending on the base color.
db9146 |
Jun 23 2018, 05:36 PM
Yes, thanks, I understand the brown/white stripe is switched which is why it connects to the back of the horn contact ring.
I'm wondering about the solid brown ground wire. I think grounding it to the steering column via one of the clam shell screws is the right answer but just trying to confirm. |
Lo-Fi Version | Time is now: 9th June 2024 - 03:10 AM |
