I pulled the horn ring off my '70 -6 and thought, "only two brown wires, one with a white stripe and one without. No problem remembering where they connect"....yea, right!
Okay, the brown wire with the white stripe has the female spade connector that slips on to the spade on the back of the horn ring. Which screw does the other solid brown wire with the grounding ring connect to?
Does it go under one of the four screws that hold the clam shell on?
