| LCOX |
Jul 11 2018, 10:40 AM
Member ![]() ![]() Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None |
Does anyone know the proper torque on the 2 small 6mm bolts that mount the oil temp sender cover plate to the bottom of the engine case? The plate that has the big red o ring?
| Dave_Darling |
Jul 11 2018, 01:23 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,365 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Very little, on the order of 5-7 lb-ft. Google "torque M6 bolt into aluminum" for more details.
--DD |
| bandjoey |
Jul 11 2018, 01:40 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
The Haynes book is 6 I think. Someone will confirm this soon. |
| Mark Henry |
Jul 11 2018, 04:03 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
IIRC They're 7.5 ft/lbs or 90 inch pounds.
The 996 has a million M6 screws, all 90in/lbs. OK... I'm exaggerating...but it's a lot. (IMG:style_emoticons/default/smile.gif) Part of a T4 rebuild I just helicoil those two holes, I'm always finding them stripped out by PO's. If it won't torque up it's stripped. |
Lo-Fi Version | Time is now: 9th November 2026 - 02:40 PM |
