| rgolia |
Aug 16 2018, 03:00 PM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 721 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
| Dion |
Aug 16 2018, 03:16 PM
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,935 Joined: 16-September 04 From: Shepherdstown, WV Member No.: 2,766 Region Association: MidAtlantic Region
Looks nice Ralph. Did you get the transmission sorted yet? Never mind just saw your other post.
Happy motoring! |
| abes914 |
Aug 16 2018, 05:32 PM
Member ![]() ![]() Group: Members Posts: 372 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California
Awesome! I am thinking of doing this as well. Can you share where you got the LED lights from and how you convert the fog light housing to fit the LED.
Thanks. |
| rgolia |
Aug 17 2018, 03:41 AM
Awesome! I am thinking of doing this as well. Can you share where you got the LED lights from and how you convert the fog light housing to fit the LED. Thanks. I thought I took pics but can’t seem to find them. Anyway I removed the bulb and cleaned out the stock bulb housing. Picked up a 35w equivalent from super bright led, need to find the part number, and fit it to the original bulb housing with clear silicone and let them set. Installation was pretty standard from there. They go in pretty much like stock. Not sure how they will perform as a fog light but the intent was to use them as a DRL. |
| jim_hoyland |
Aug 17 2018, 04:07 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,161 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Great idea ! I would like to convert late fog lamps to LED
| 76-914 |
Aug 17 2018, 08:05 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,995 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Awesome! I am thinking of doing this as well. Can you share where you got the LED lights from and how you convert the fog light housing to fit the LED. Thanks. I thought I took pics but can’t seem to find them. Anyway I removed the bulb and cleaned out the stock bulb housing. Picked up a 35w equivalent from super bright led, need to find the part number, and fit it to the original bulb housing with clear silicone and let them set. Installation was pretty standard from there. They go in pretty much like stock. Not sure how they will perform as a fog light but the intent was to use them as a DRL. Alright, you lost me there. So the new bulb base is a smaller size and it is glued in with Silicone? I didn't find the LED equivalent bulb at Super Brite but then again I'm not that bright myself. (IMG:style_emoticons/default/av-943.gif) |
| Mark Henry |
Aug 17 2018, 12:26 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Is there a plug in LED bulb for the Pilot fog lights?
IIRC they are H3... but I've been known to be wrong. (IMG:style_emoticons/default/confused24.gif) |
| Mikey914 |
Aug 17 2018, 04:18 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,786 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I was looking for the stock reflectors and no luck with anything bright enough that can fit. If you can find some I'd stock them.
| rgolia |
Aug 18 2018, 04:52 AM
Lo-Fi Version | Time is now: 22nd November 2026 - 11:43 PM |
