> Euromeister 17 x 7 fuchs on narrow body, I tried looking... couldn't find pics
Mark Henry
post Aug 18 2018, 09:08 AM
that's what I do!
I'm going to try Euromeister 17 x 7" (ET23) on narrow body, because I found a pair here in Canada for cheap, saves me about $200 of importing a full set.
Just wondering how they fit, from a tire calculater it seems with a 205/50-17 tire it will only push the tire out less than a 1/4" more than the 205/60-15's I now have. If that's all it is they should fit my rear fenders with no mod or just a slight roll of the rear part of the lip.
I really like the look of the 15" fuchs with 205/60-15 tires, but the all season passenger car tires I have just plain suck.
The pro is 17" tires are cheap and you have a good selection of performance tires.
The con is I've never cared for the big rim baby buggy look. It just doesn't work for me on a vintage 914. The other con is they're not real and heavier.
But someone posted a set where they painted the lip black creating a faux higher side wall look that I really liked.
I've tried searching to find this pic but have had no luck, hopefully the member will see this and repost the pic.
dr914@autoatlanta.com
post Aug 18 2018, 10:11 AM
17 by seven will fit if they have the correct offset, but the standard 911 914 offset in a seven inch wheel will not fit. People are installing 7.5 Boxster wheels on their four cylinder by first installing an inch wide four to five lug adaptor and then bolting on the wheels,. The Boxster wheels have such an inset that they actually have to be spaced out to fit a 914 narrow body. It is an easy conversion and gives the 914 a modern look if that is what you like, still a 205 tire though
QUOTE(Mark Henry @ Aug 18 2018, 08:08 AM) *
Mark Henry
post Aug 18 2018, 11:40 AM
that's what I do!
The big questions I have is if anyone who's done this, is the ET23 correct offset?
I believe it is... but I'm working from memory.
And does anyone have pics?
Not interested in sizes or rims other than 17x7" euromeister please.
horizontally-opposed
post Aug 18 2018, 11:48 AM
Yep! Been done...
http://forums.pelicanparts.com/porsche-car...utlaw-sale.html
sixnotfour
post Aug 18 2018, 11:52 AM
L have 2 sets of the 5lugs ,,one with 205/45 and one with 205/50'
I like the 50s way better
sixnotfour
post Aug 18 2018, 12:23 PM
QUOTE(Mark Henry @ Aug 18 2018, 11:40 AM) *
my 5lug 17 x 7s are et 40 5.5 inch backspace
sixnotfour
post Aug 18 2018, 12:31 PM
these are et 40 also ..
https://www.carid.com/klassik-rader-wheels/...3AaAnQAEALw_wcB
et23 is what the factory 15x7s have and most rub
euromeisters are et 23
Mark Henry
post Aug 18 2018, 12:46 PM
that's what I do!
QUOTE(sixnotfour @ Aug 18 2018, 02:23 PM) *
Damn it's ET 40 I need?
I don't see an ET40 listed???
https://www.automotion.com/porsche-euromeister
Chris914n6
post Aug 18 2018, 01:00 PM
Jackstands are my life.
Long story deleted.... you will be fine, maybe need to move 1/2* camber.
Post pics. I'm thinking to replace my Boxster 16s with those.
Mark Henry
post Aug 18 2018, 01:08 PM
that's what I do!
Dang I thought 020 was ET20 but turns out stock 15x6 are ET36
ET23.3 I believe would make them stick out 3/4"...NFG. (IMG:style_emoticons/default/sad.gif)
Where did you get the 17x 7 ET40 rims?
https://www.willtheyfit.com/index.php?width...&offset2=23
Factory wheel info
https://members.rennlist.com/911pcars/WheelWts.html
post Aug 18 2018, 01:24 PM
Sorry missed the key "narrow body" part, Mark!
Carry on...
sixnotfour
post Aug 18 2018, 01:41 PM
CIP 1 has em, L bought my 2 sets off SAMBA as the VW guys are worse than porsche guys when it comes to changing wheel preference..
I paid $450 for 4 with 205/50s like new
the second set with 205/45s and a 5th wheel stlll in the bow. $650 like new
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13-9739
no 23 will not fit under stock wells
QUOTE(Mark Henry @ Aug 18 2018, 10:40 AM) *
Mark Henry
post Aug 18 2018, 04:20 PM
that's what I do!
Dang (IMG:style_emoticons/default/sad.gif) I hate reneging on a deal, but money hasn't changed hands.
Chris914n6
post Aug 18 2018, 07:36 PM
15x7 Fuchs are et23. Cookies are 15x7 et23. A 205 tire is pretty much 205 wide at the tread. So why doesn't the 17x7 et23 fit with a little rolling????
My 225/50 on 16x7 et40 +15mm spacer Boxsters fit great with DD's autox alignment. Then I bought an Eastwood tool and rolled the (IMG:style_emoticons/default/stromberg.gif) out of them that looks like they'll fit a 235-245.
Spoke
post Aug 18 2018, 08:16 PM
Jerry
Euromeister 7x17 on the front and 9x17 on the rear. Fit nicely and looks good.
DRPHIL914
post Aug 18 2018, 08:52 PM
Dr. Phil
QUOTE(Chris914n6 @ Aug 18 2018, 09:36 PM) *
i have stocke 16” fuchs, and we put 205/55 on them, have been rolled ans still rubbed and blistered paint, went thru a lot to make fenders look like new after someone made a huge mess of my fenders- these do now fit but still so close that with a new paint jobi am not chancing it- - answer to your question is some may make it due to variation in the cars since they were hand made. i had more room on one side than the other. i had 3 choices- 1. use 944 wheels- they go in just under1/2” on inside and outside and give you enough room with 205’s- 2. use a 195 tire in that same brand to get a slightly smaller tread width , i would have had 1/4 more room on outside , OR 3. use a tire brand that is not as wide- not all 205 tires are the same!.
I opted for a 4th choice, keep my 205/55 Bridgestone potenza and put them on a 16x6 fuchs, same as front- .
also as stated by another, you could increase your camber - i have a stock set up but if i increased this it may have fiven me the safe clearance i wanted with my 7” rims- just dont have thr time to sort thst all out or the $$ to spend on changing tires etc- i already have the set of 6’s
Chris914n6
post Aug 18 2018, 10:56 PM
QUOTE(Philip W. @ Aug 18 2018, 07:52 PM) *
That was me too, and I told you a long time ago on your thread to just tweak the camber and be done with it, but...
SO.O.C914er
post Aug 18 2018, 11:35 PM
Damn that badpnny car is bad ass. I like everything about it! Well done.... (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/first.gif) ......Paul
- Lo-Fi Version Time is now: 17th March 2026 - 05:54 PM
