Lookng for source for CIS nipple |
Dr Evil |
Jun 15 2005, 12:32 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Hello all,
I am looking for a place to purchase the nipple that goes onto the CIS pressure accumulator. It is a wierd thread and size and I have had no luck locally. I knew that CIS was used on many cars so I went to Ecology auto wrecking and pulled one off of an accumulator for a VW Fox or Jetta. The only problem now is that the inner and outer diameter of the nipple part itself are too small. The part that attaches to the accumulator itself is the right size, though. What can I do? I'll try to take a pic today so I cna clear this up if I am confusing anyone. Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
ArtechnikA |
Jun 15 2005, 01:06 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Earl's has an AN-6 adapter for that. it's in the power steering section of their adapters. you will need a fairly fat-section O-ring, but otherwise works fine with the VW CIS (BTDT).
in San Diego - the big Earl's distributor was Industrial Liquidators in Kearney Mesa on Ruffner Road between Clairemont Mesa Boulevard and Raytheon Rd. (couple blocks east of 805). donno if they're still there, but it's where i'd try first... |
messix |
Jun 15 2005, 01:11 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
cis nipples? would that be las vegas, miami, or new york?
i vote miami ! (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
Joe Ricard |
Jun 15 2005, 02:07 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Dats a pink nipple... I'll take 2 please. Lots of CIS cars in the junk yards. Bet you can find one there. Or a Dealer of Audi VW Porsche Mercedes |
Dr Evil |
Jun 18 2005, 11:42 PM
So far I have had no luck with Industrial Liquidators (all of thiers were inverted flange), or any of the Porsche parts places that I have called. No one had it on the schematic. Here is a pic for ya'll to consider. I hope that someone can help me find this piece.
Attached thumbnail(s) |
Dr Evil |
Jun 18 2005, 11:43 PM
Piece removed.
Dr Evil |
Jun 18 2005, 11:45 PM
Here is the smaller one that I keep finding in the junkyards side by side with the one I need.
Attached image(s) |
Dr Evil |
Jun 18 2005, 11:46 PM
another side by side.
Attached image(s) |
ejm |
Jun 19 2005, 07:22 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
So the threaded part is correct but the hose barb is too small? I've got a box of CIS stuff...could prolly match it up with some exact measurements
ArtechnikA |
Jun 19 2005, 08:49 AM
sorry if i wasn't sufficiently explicit before...
here's the Earl's application page: Earl's Powers Steering and FI Adapters this is the part you need: 991955ERL 16mm x 1.50 AN-6 Power Steering / Fuel Injection - "O" Ring Seal 991956ERL 18mm x 1.50 AN-6 Power Steering - "O" Ring Seal i don't recall if you need the 18mm or the 16mm - IIRC it's the 16 but it doesn't matter - get whichever size you need. you WILL need a thick cross-section O-ring (i may have mentioned this before). if you're using AN-6 fuel hose, you're done - just get an appropriate hose end and connect. if you're *not* using AN-6, you can get an adapter to whatever you're're using from the AN-6 fitting. i have done this, it works. |
Dr Evil |
Jun 19 2005, 09:44 AM
Ed,
that is exactly correct. The barb that I need has a ID of approx 6mm and an OD of about 8mm. If you have this part, that would be awsome! Rich, I'll look into that if the OE part is impossible to find. Thanks guys! |
ejm |
Jun 19 2005, 11:15 AM
how's this....6mm bolt just slides inside the nipple...the barb is 8-8.5mm depending where it's measured (peak/valley)...the thread fitting is sitting next to a nut that measures 13mm across the flats....the fitting itself is 17mm across the flats and has internal threads 12X1.5mm...a 914 wheel bolt threads into it...
Attached image(s) |
Dr Evil |
Jun 19 2005, 11:20 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Thats it! The nut is not necessary as the nipple fits inside many sizes of nuts. But, the nipple measurements are right on! What do I owe you? You rock (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
ejm |
Jun 19 2005, 01:12 PM
Send me a PM with your address....you can buy me a beer at Hershey '06 (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif)
Dr Evil |
Jun 19 2005, 01:36 PM
Done! Thanks.
ChrisReale |
Jun 19 2005, 02:01 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
This is what 914club is all about! Right on guys (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Lo-Fi Version | Time is now: 7th June 2024 - 11:11 PM |
