Rear Porterfield Brake Pad Installation, Retaining pin too wide |
saigon71 |
Aug 24 2018, 12:26 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'm working on replacing my old rear brake pads with a new set of Porterfields. The problem is that the old ones have one larger hole to accommodate the retaining pin that is a larger diameter.
In the pics, the lower pad is the old one, porterfields are on top. Do these differ by model year? Do I need to "hog out" that hole on the porterfields? Thanks. |
TheCabinetmaker |
Aug 24 2018, 01:00 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I've seen it many times with different pads. Just ream it out.
914Sixer |
Aug 24 2018, 01:12 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Brake pads fit LOTS of European cars. Been that way for years. Just make it bigger.
brant |
Aug 24 2018, 01:31 PM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I bored out the hole on my current set of portefields (street car)
no long term problems as a result |
914_teener |
Aug 24 2018, 02:37 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I'd get a new pin as well.
steuspeed |
Aug 24 2018, 11:57 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Yup. same thing on my Porterfields. Hog one out. I bought a metal removal grinding bit at ACE hardware.
Eric_Shea |
Aug 29 2018, 03:24 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
From the AP30 Rear Pad Landing page on our site:
***These require enlargement of one retaining pin hole*** And the story behind the pin holes - Because 914 rear calipers do not have the 20 degree piston notch, original pads were actually chamfered to angle in the face of the oncoming rotor. Because the pads were directional in the past, ATE had the two pins made at different sizes to ensure the pads would be installed in the proper direction. Pads are no longer chamfered and they no longer (for the most part) come with the "914 only" backing plates. The solution is to simply drill out one of the holes on your pads to match or, take your "fat pins" in to a machinist and have the larger pad rests machined off them. Is it a big deal not having chamfered pads? Will my brakes squeal now? Not really. If you follow the proper bedding procedures on our site you will be squeal free (and no... goops and gums and sprays don't work, bedding your pads properly will be the best way to eliminate squeal from your new pads). |
Lo-Fi Version | Time is now: 8th June 2024 - 10:25 AM |
