ground strap location, where does the strap from the (-) battery terminal ground to? |
DRPHIL914 |
Sep 3 2018, 10:01 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i know this is silly but i pulled this all apart almost a year ago- i have all the other connectors accounted for except this and maybe one other
cary |
Sep 3 2018, 10:05 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Right above the battery in the corner up against the sound pad.
DRPHIL914 |
Sep 3 2018, 10:12 PM
Right above the battery in the corner up against the sound pad. ok! but why is the strap so long? ok i think i remember that now, but what is this one that is so long? where does it go? Attached thumbnail(s) |
worn |
Sep 3 2018, 10:19 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Right above the battery in the corner up against the sound pad. ok! but why is the strap so long? ok i think i remember that now, but what is this one that is so long? where does it go? That the positive cable to the starter? Edit: yeah I think I see the firewall grommet if I am looking correctly. |
DRPHIL914 |
Sep 3 2018, 10:24 PM
ok, ao this goest to the starter, , and the other bunch of red wires are the positive to the harness! ,
and the second pic, i had this in a box, , could it be used for battery ground? Attached thumbnail(s) |
DRPHIL914 |
Sep 3 2018, 10:50 PM
found this picture from back when i was taking it all off- shows the positive , the 4 reds, and main one is the black one that i have that is long and goes to the starter- mystery solved but i have to find that ground strap for battery to body
mepstein |
Sep 4 2018, 05:21 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
found this picture from back when i was taking it all off- shows the positive , the 4 reds, and main one is the black one that i have that is long and goes to the starter- mystery solved but i have to find that ground strap for battery to body They sell them at flaps for a couple dollars. Nothing special. |
worn |
Sep 4 2018, 08:28 AM
ok, ao this goest to the starter, , and the other bunch of red wires are the positive to the harness! , and the second pic, i had this in a box, , could it be used for battery ground? Yes, the lower cable would go to the negative terminal and the grounding stud on the car body. Looks like it was replaced with the braided type of cable. The originals were insulated. I personally like the braided cables cause they are flexible. |
Bartlett 914 |
Sep 4 2018, 09:41 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Don't forget the ground strap from the transmission to the body!
DRPHIL914 |
Sep 4 2018, 10:28 AM
Triaddave |
Sep 4 2018, 10:40 AM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
You mean the ground strap from the tranny to the body, the one we always forget to disconnect when we pull the engine?
DRPHIL914 |
Sep 4 2018, 11:13 AM
You mean the ground strap from the tranny to the body, the one we always forget to disconnect when we pull the engine? they sent me the wrong one, but anyway don't think my tranny-body strap is really that bad, i just thought i would put a new one on since the motor and trans were out for paint. - i have to clean off the paint from the grounding spot, but that may be about all i have left to do besides hook up the battery, and i should be able to start it. !! |
Lo-Fi Version | Time is now: 1st June 2024 - 11:54 AM |
