milwlandrover |
Member ![]() ![]() Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest ![]() |
I have the transmission and linkage sorted and installed and so far am very happy with it. I am ordering a Tangerine exhaust today (nothing overly load but I want people to know it is a Porsche. It will be just a driver.
I also want to replace the rotors and shoes on the brakes. any recommendations here? thanks |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,954 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Call pmbperformance. They are the Porsche brake guys.
walterolin |
Senior Member ![]() ![]() ![]() Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States ![]() |
Agree with Mark. PMB - Eric Shea.
I have a late '70 1.7, similar to yours. I decided to rebuild my calipers front and rear just to see why the Haynes manual said the rears could only be rebuilt by the factory. Turned out to be another error in Haynes. You can rebuild yourself, but you won't save much, and Eric's calipers look good. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
BTW, there are no brake "shoes" on the 914. Those would be for drum brakes, which the 914 doesn't have. You would be getting "brake pads". (IMG:style_emoticons/default/smile.gif)
The factory wanted you to buy new calipers from them rather than rebuild the rears. Those are a bit more complex than the fronts, which is probably why they just didn't want to deal with it. (Plus selling more parts == more profit.) We've known how to rebuild them for a couple of decades, and we have collectively figured out how to get correct replacement parts for most of the stuff that might go wrong. But PMB is very much the "easy" button for stuff that is done completely right. A few things: - Stock four-cylinder front brake rotors are integrated with the front hubs. Replacing the rotors means replacing the hubs, therefore also the bearings and dust seals. - If you have five-lug wheels, you will need to look at how that conversion was done before you buy any parts. Because often the five-bolt stuff is very very different than the stock four-cylinder cars' four-bolt stuff. - Post pics here if you have questions about what you have. - The rear venting clearance listed in the manuals is double what you should use. Going with the stock spec results in an even longer brake pedal before you get some bite. --DD |
milwlandrover |
Thanks to everyone for the info. I typed shoes, but meant pads. I hope to pull them apart tonight to see where I am at and exactly what I need.
Cheers! |
Lo-Fi Version | Time is now: 4th July 2025 - 09:13 AM |
