My '73 1.7 is a total whiner |
Tdskip |
Sep 28 2018, 08:49 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
So the really good news is that I got her running and she seems healthy, so I'm way ahead of the game here but I do have an issue that I need some additional brain power on please.
Several fuses were missing from my car, and when I put a proper size fuse in number 11 I get a warning buzzer that operates continuously until you put the key in the ignition and start the car. That is not correct behavior, and doesn't seem to tie back to the fuse chart that I've seen. I am assuming wiring on the back of the fuse panel is wrong. Any other ideas? Thanks! |
carking1996 |
Sep 29 2018, 05:43 AM
Member Group: Members Posts: 69 Joined: 15-September 16 From: Ohio Member No.: 20,399 Region Association: North East States |
Buzzer sounds like it would be the seat relay under passenger seat. Most of us have disabled that already. (IMG:style_emoticons/default/smile.gif)
Regarding the fuses specifically... (IMG:http://www.914world.com/bbs2/uploads_offsite/c767170.r70.cf2.rackcdn.com-20399-1538221393.1.jpg) |
Tdskip |
Sep 29 2018, 11:17 AM
Buzzer sounds like it would be the seat relay under passenger seat. Most of us have disabled that already. (IMG:style_emoticons/default/smile.gif) Regarding the fuses specifically... (IMG:http://www.914world.com/bbs2/uploads_offsite/c767170.r70.cf2.rackcdn.com-20399-1538221393.1.jpg) Hey! Good morning and thanks for the response. That is very helpful . It can't be correct behavior that that thing goes off constantly until the ignition is on however, right? I've never check to see what happens if there's no one sitting in the driver seat, but it sounds like I may just be best off disconnecting that specific buzzer. |
mgphoto |
Sep 29 2018, 02:21 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Sounds like the buzzer relay is positioned in the relay socket incorrectly.
Check the pin alignment. |
Tdskip |
Sep 29 2018, 06:10 PM
euro911 |
Sep 30 2018, 12:26 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Bad door switch?
Not sure about the 914, but my Tacoma had a buzzer issue (with the motor off, but key in the ignition switch). Replaced the switch - buzzer silent (unless I open the door(s). |
Tdskip |
Oct 1 2018, 09:46 AM
Bad door switch? Not sure about the 914, but my Tacoma had a buzzer issue (with the motor off, but key in the ignition switch). Replaced the switch - buzzer silent (unless I open the door(s). Hi Mark, thanks for the response. Good idea on checking that. My door switch is actually working, I can hear it go on/off when I press it as an additional buzzer in addition to the one that is always on. |
Robnxious |
Oct 1 2018, 10:12 AM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
Without hearing it, I have to agree w/ Carking on the seat relay. When I re upholstered my seats, I saw a relay wasn't connected under the passenger seat. Plugged it in, and started getting a constant buzzing when I started it up. Unplugged it again, and "voila" it's fixed.
Lo-Fi Version | Time is now: 7th June 2024 - 09:54 AM |
