Where to get 73-76 50mm Crank Journals? |
Stark 01 |
Nov 1 2018, 09:54 AM
Racing newbie Group: Members Posts: 43 Joined: 26-May 14 From: Concord, NC Member No.: 17,404 Region Association: South East States |
I am rebuilding a race engine from a fire, and the builder is saying he keeps getting the wrong size crank journals from his supplier even though he is ordering the correct part number.
Anyone know for sure who sells the correct Crank Journals for a 2.0L 1973-76? |
Mark Henry |
Nov 1 2018, 10:38 AM
You have the wrong terminology, a crank journal refers to the area on the crank the rod or main bearing runs on.
He may be referring to wrong size of the journal for the bearings he has. As far as buying a new, stock crank only thing available is used, NOS (new old stock) or chinese. I'd rather have a used STD/STD or .010/.010 german crank than a new chinese crank. If it's a stroker crank chinese or welded is the only options. There's also billet, but they are very expensive. You also can get rod bearing/journals sized for chevy 2", this could be what the supplier is sending, very close to 2 liter size journal but not correct, needs special bearings and rods. |
dr914@autoatlanta.com |
Nov 1 2018, 11:13 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
so rod and main bearings he needs in .50 ??
I am rebuilding a race engine from a fire, and the builder is saying he keeps getting the wrong size crank journals from his supplier even though he is ordering the correct part number. Anyone know for sure who sells the correct Crank Journals for a 2.0L 1973-76? |
Stark 01 |
Nov 1 2018, 07:48 PM
On the phone with the builder, I wrote down 50mm crank journal
You think he meant bearings? so should I be looking for 50mm bearings?? |
rhodyguy |
Nov 2 2018, 08:10 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
50MM=1.969". What crank shaft and rods is your builder using?
Stark 01 |
Nov 3 2018, 06:56 PM
porschetub |
Nov 4 2018, 01:24 AM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
or perhaps find I new engine builder,all he needs to do is read the numbers on the back of the old shells ????,this will give you the correct size.
The 71mm crank was offset ground from 66mm from the factory so has smaller big end journals . |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:14 AM |
