Fresh air blower box, Hitting wiper motor |
shane |
Nov 1 2018, 08:09 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
I’m trying to reassemble my blower box and wiper assembly. I’m having trouble with the back of the blower box hitting the wiper motor and not allowing the blower box to come up enough the make a seal on the vent grate. Is it really that tight of fit or do I have something wrong? The wiper motor rests on the back of the blower box. Any help would be appreciated, thanks.
raynekat |
Nov 1 2018, 09:07 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I’m trying to reassemble my blower box and wiper assembly. I’m having trouble with the back of the blower box hitting the wiper motor and not allowing the blower box to come up enough the make a seal on the vent grate. Is it really that tight of fit or do I have something wrong? The wiper motor rests on the back of the blower box. Any help would be appreciated, thanks. Had the same issue. The wiper motor needs to swing backwards a bit more. Not sure how to tell you how to do that....it just has to happen. Push on the wiper assembly a bit and it should move or swing more towards the rear of the car, |
cary |
Nov 1 2018, 10:00 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
The wiper assembly attaches to the front bulkhead with a rubber buffer like this one.
It keeps it tucked back in the right location. https://www.belmetric.com/metric-rubber-buf...fer-p-5692.html Edit : Found this shot in The Samba |
shane |
Nov 2 2018, 10:46 AM
The wiper assembly attaches to the front bulkhead with a rubber buffer like this one. It keeps it tucked back in the right location. https://www.belmetric.com/metric-rubber-buf...fer-p-5692.html Edit : Found this shot in The Samba Thanks for the info! mine has that buffer intact and in one piece but it still needs to come back more. I must have something a little off but can’t think of anything to change but a shorter buffer. That bracket is beefy so I know it didn’t bend. |
raynekat |
Nov 2 2018, 11:05 AM
Shane, not sure how to best explain it.
Mine did the same thing as yours....blower was hitting the wiper assembly. My wiper assembly while loosely bolted in would rock back or pivot a little more to the rear. You don’t have to force anything or bend something. Loosen up the 2 big nuts on the outside of the cowl and press a bit on the lower part of the wiper assembly. Mine pivoted back a notch when I did that. Good luck. |
bbrock |
Nov 2 2018, 11:09 AM
The wiper assembly attaches to the front bulkhead with a rubber buffer like this one. It keeps it tucked back in the right location. https://www.belmetric.com/metric-rubber-buf...fer-p-5692.html FYI, 914Rubber makes that buffer/mount (IMG:http://www.914world.com/bbs2/uploads_offsite/shop.914rubber.com-20845-1541178597.1.jpeg) |
shane |
Nov 2 2018, 06:20 PM
Shane, not sure how to best explain it. Mine did the same thing as yours....blower was hitting the wiper assembly. My wiper assembly while loosely bolted in would rock back or pivot a little more to the rear. You don’t have to force anything or bend something. Loosen up the 2 big nuts on the outside of the cowl and press a bit on the lower part of the wiper assembly. Mine pivoted back a notch when I did that. Good luck. Great thanks, I will give it a try like you said. |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:55 AM |
