Locking driver's side door |
partwerks |
Nov 13 2018, 09:00 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
When locking the driver's side door, and holding the flap to close the door, it just bounces back and doesn't lock, and so wondering where the problem is?
Chi-town |
Nov 13 2018, 09:13 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
I thought you had to close door, lock with key?
partwerks |
Nov 13 2018, 09:22 PM
PS you always had to lock it, and slam the door shut. End of story, but as I recall the DS you locked it, and then held the flap till it closed, but in this case the body shop must have botched something up?
seanery |
Nov 13 2018, 09:39 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,852 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
hmm, i thought it was always with a key, too
sb914 |
Nov 13 2018, 09:41 PM
Surf Guru Group: Members Posts: 4,306 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Check the door jam receiver part. Sometimes the lever is in wrong position.
Used to happen to my vw bug. |
sb914 |
Nov 13 2018, 09:43 PM
And You don't need key to lock door !
TheCabinetmaker |
Nov 14 2018, 09:03 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Seriously guys? (IMG:style_emoticons/default/screwy.gif) You must lock the drivers door with a key. It's not broke! It's made that way, so you don't lock your keys in the car!!
sb914 |
Nov 14 2018, 09:14 AM
Seriously guys? (IMG:style_emoticons/default/screwy.gif) You must lock the drivers door with a key. It's not broke! It's made that way, so you don't lock your keys in the car!! Really ? Go try it. I lock my door Without key every time. (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Nov 14 2018, 09:23 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) The psg door will lock w/o holding the handle but the driver will lock w/o the key. My 76, 73 & 70 do anyways! (IMG:style_emoticons/default/beerchug.gif)
sb914 |
Nov 14 2018, 09:24 AM
Thanks Kent !
Steve |
Nov 14 2018, 09:28 AM
914 Guru Group: Members Posts: 5,594 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) The psg door will lock w/o holding the handle but the driver will lock w/o the key. My 76, 73 & 70 do anyways! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) Same with my 75 and previous 73. Try it...... I've owned 914's since the late 70's and they've always worked this way. |
sb914 |
Nov 14 2018, 09:31 AM
Seriously guys? (IMG:style_emoticons/default/screwy.gif) You must lock the drivers door with a key. It's not broke! It's made that way, so you don't lock your keys in the car!! I taught a old dog a new trick. (IMG:style_emoticons/default/poke.gif) |
sb914 |
Nov 15 2018, 08:47 AM
dr914@autoatlanta.com |
Nov 15 2018, 09:06 AM
914 Guru Group: Members Posts: 7,869 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the catching mechanism is dirty, you will have to remove it and clean. It is getting stuck midway between open and locked that is what is doing it. An easy repair once you remove the door panel
When locking the driver's side door, and holding the flap to close the door, it just bounces back and doesn't lock, and so wondering where the problem is? |
partwerks |
Nov 15 2018, 09:12 PM
It is in that position. I was also told by a second person it might just need cleaned.
Lo-Fi Version | Time is now: 23rd May 2024 - 01:43 AM |
