Subaru Engine Mount |
Heater Guy |
Nov 21 2018, 08:42 PM
Member Group: Members Posts: 74 Joined: 20-October 09 From: Walnut Creek, CA Member No.: 10,960 Region Association: Northern California |
The beauty of this motor mount (unlike a cradle) there are no obstructions in the way of exhaust system, half shafts, cable shifter, etc. When we pull the transaxle, we don't need to support the rear of the engine as the motor mount and cross bar are strong enough to support the engine when the transaxle is removed. When the transaxle is installed, there is a separate mount that supports the rear of the transaxle. Transaxle mount is sole as a separate piece. To allow for the 1/2" motor plate a 1/2" aluminum spacer is installed between the crankshaft and flywheel. The modified motor plate provides enormous amount of strength to resist the torque of the engine. This 2.7 L engine with 30 psi boost puts out over 550 WHP and over 500 ft-lbs torque. The cross bar mounts to the tub with two simple weld-in U shaped brackets. To drop the engine, remove two bolts and it's out. $1,250.00 |
914werke |
Nov 21 2018, 08:49 PM
"I got blisters on me fingers" Group: Members Posts: 10,116 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
so does it used the rubber mounts at the outboard /4 mount location?
Chi-town |
Nov 21 2018, 10:59 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
If you don't like a lot of vibration it will need rubber mounts at the front and a redesign on the rear mount.
Lo-Fi Version | Time is now: 1st June 2024 - 09:06 AM |
