Christmas Sale at Spokeworks, 10% off all products |
Spoke |
Nov 24 2018, 07:46 AM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Christmas sale now till end of the year.
Spokeworks LED 10% off all products. Take another 5% off the sale price for orders over $200 using the coupon "spoke" when checking out. Wishing everyone a Merry Christmas and Happy New Year. Thank you for your support. Spoke We do custom LED projects for those unique applications. Here's a Ferrari 348 with custom taillight fixtures and custom LEDs. A gentleman from Belgium wanted to surprise his uncle with custom running lights for his 356 for Christmas last year. However a 6 week project turned into 6 months but turned out quite unique. Here's a picture of the hood-mounted lights. The lights turned out to be quite bright. We used 19 soft white power LEDs with focusing lenses. To dissipate the heat the LEDs were backed with a large heat sink and the switching converter placed on a separate PCB. On the non-LED side, I designed a small motor controller for my model railroad club. This controller is used to power animations on the layout. BTW, if you happen to be near Ambridge, PA during the weekends in December, check out the Ohio Valley Lines layout at our open house. Ohio Valley Lines |
ConeDodger |
Nov 24 2018, 05:26 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I’ve got every one of Spoke’s 914 products but one, an im’a order that one now cause - SALE ! (IMG:style_emoticons/default/evilgrin.gif) |
mb911 |
Nov 25 2018, 02:50 PM
914 Guru Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I may have to buy some of these. Need to sell some of parts as well to fund em.
Coondog |
Nov 25 2018, 03:49 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Best bang for your buck Mods out there..... (IMG:style_emoticons/default/smile.gif)
914Sixer |
Nov 26 2018, 06:23 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Ordered up some side marker lights
dan10101 |
Nov 27 2018, 04:06 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Do you have anything that could be used as headlights in the 914 front turn signal pod? Doesn't have to be plug and play, but I'm seeing what's out there.
Felix's car as an example.. |
Andyrew |
Nov 27 2018, 04:27 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Do you have anything that could be used as headlights in the 914 front turn signal pod? Doesn't have to be plug and play, but I'm seeing what's out there. Felix's car as an example.. Not that i've seen. Only Felix and Garland Garlands build. I'd read the whole thread. His headlight mod (earlier page) is pretty cool http://www.914world.com/bbs2/index.php?s=&...t&p=2375311 |
Spoke |
Nov 30 2018, 06:16 AM
Do you have anything that could be used as headlights in the 914 front turn signal pod? Doesn't have to be plug and play, but I'm seeing what's out there. Felix's car as an example.. Thanks for asking although I haven't done much with high power headlight applications. Applications like these require an entire fixture to work correctly. The LEDs that I do are mainly low power drop-in boards to existing fixtures for marker, brakes, and turnsignals. The only thing I did was some Marchal running lights with LEDs for a 356. This was a one-off to see if I could do it. It worked out pretty well although as a headlight it doesn't have that sharp upper cut-off like modern headlights have. Attached thumbnail(s) |
dan10101 |
Nov 30 2018, 01:34 PM
Do you have anything that could be used as headlights in the 914 front turn signal pod? Doesn't have to be plug and play, but I'm seeing what's out there. Felix's car as an example.. Thanks for asking although I haven't done much with high power headlight applications. Applications like these require an entire fixture to work correctly. The LEDs that I do are mainly low power drop-in boards to existing fixtures for marker, brakes, and turnsignals. The only thing I did was some Marchal running lights with LEDs for a 356. This was a one-off to see if I could do it. It worked out pretty well although as a headlight it doesn't have that sharp upper cut-off like modern headlights have. Thanks, you do nice work. |
Spoke |
Dec 4 2018, 04:31 PM
By the way, for orders $200 and over, take an additional 5% off the sale price using the coupon "spoke" when checking out.
Remember to routinely check all exterior lights on your car even if they're LEDs. The actual LED component may have a much longer life expectancy than incandescent bulbs but they are more complex and have a lot more circuitry. With circuit boards, resistors, diodes, capacitors, transistors, and ICs controlling the LED current, the LED lights on a car have many more failure potentials than the filament light bulb. Here's some examples. There's something amiss with this Prius's left brake light as it is much dimmer than the passenger side. The running lights are not on in the picture so whatever circuitry drives the left side lights is having issues. The LEDs are lit but not very bright. It appears that one of the LEDs in the center row near the outside of the vehicle might be completely out. I doubt this will pass vehicle inspection. Wonder what this will cost to repair? The LEDs on this truck are on their way out. The outside driver side LED has all 10 LEDs on. The other 3 lights have some sort of issue unless this unit has a smiley/frowny face feature. Looks like there's 5 strings of LEDs with 2 LEDs in each string. Even those folks who have retired to The Villages in Florida may need to check the LED brake lights on their carts. In this blurry picture a couple of the LEDs are out on the driver side. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:04 PM |
