New hardware source?, Rear trunk hinge bolt |
Morph914 |
Dec 4 2018, 11:03 AM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
Anyone know where to find new rear trunk hinge bolts? I have seen the kits at Pelican and AA but my mounts appear to be fine. I just want to replace the worn and bent bolts.
Cheers, John |
ValcoOscar |
Dec 4 2018, 11:06 AM
Garage Life Group: Members Posts: 2,389 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
John-
I have TWO of these for you, blasted newly yellow zinc plated. $10/shipped let me know, Oscar |
Morph914 |
Dec 4 2018, 12:00 PM
ValcoOscar |
Dec 4 2018, 12:07 PM
John- I have TWO of these for you, blasted newly yellow zinc plated. $10/shipped let me know, Oscar Yes, please. Ill pay pal the $ now. Thank you $10.00 PayPal rec'd...I'll get them out. (IMG:style_emoticons/default/14.gif) Oscar |
dr914@autoatlanta.com |
Dec 4 2018, 12:11 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
TravisNeff |
Dec 4 2018, 01:13 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Ooh! added to the little detail list..
Dec 4 2018, 01:47 PM
jim_hoyland |
Dec 19 2018, 05:30 PM
Get that VIN ? Group: Members Posts: 9,321 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
we just ran a lot of 270 of them. Beautifully cad plated 9.50 each Anyone know where to find new rear trunk hinge bolts? I have seen the kits at Pelican and AA but my mounts appear to be fine. I just want to replace the worn and bent bolts. Cheers, John Nice ! (IMG:style_emoticons/default/smile.gif) Are the front and rear bolts the same ? |
914werke |
Dec 19 2018, 05:50 PM
"I got blisters on me fingers" Group: Members Posts: 10,146 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Nice ! (IMG:style_emoticons/default/smile.gif) Are the front and rear bolts the same ? They are, but the ones up front dont suffer the corrosion that the rears do due to the open side vents. |
914werke |
Dec 19 2018, 05:55 PM
George its hard to tell from your pic but do those have the nylon insert like the OE ones?
jim_hoyland |
Dec 19 2018, 06:12 PM
George its hard to tell from your pic but do those have the nylon insert like the OE ones? ? What is a Julian insert ? (IMG:style_emoticons/default/sad.gif) |
914werke |
Dec 19 2018, 06:26 PM
Dec 19 2018, 07:24 PM
Olympic 914 |
Dec 19 2018, 07:47 PM
Group: Members Posts: 1,677 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
In a previous thread someone mentioned a grease fitting mod on these bolts.
Because... these need to be kept well lubricated every time you service your 914 so that they will not seize to the trunk hinge and break the bracket. Replacing the bracket is NOT FUN!!!!!!!! Any one else heard of this? …… Pictures..? I understand how it could be done., Cut a groove on the lathe and drill it for a grease fitting. Think its worth it? I am in the middle of replacing these brackets now. |
914werke |
Dec 19 2018, 07:59 PM
no nylon insert at any time from the factory, metal to metal contact between the shoulder bolt and the trunk hinge just grease. George its hard to tell from your pic but do those have the nylon insert like the OE ones? Oh Contrair! I can show you pics of several that come straight off an unmolested car. They did come with a nylon insert like the shift rod coupler cone screws. |
IronHillRestorations |
Dec 20 2018, 07:46 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've modified those shoulder bolts for a grease fitting.
Drill down the center for a zerk fitting, and cut a groove in the shoulder then a 1/32 cross hole in the groove. I'm pretty sure jerhofer@914world.com has these on his car ( don't think I got the tag correct) |
Dec 20 2018, 09:06 AM
Please do not go out on a limb here, I always have an open ear, but being slid under my first 914 in 1974 and having observed thousands over the years, I really think that you are writing about the trunk hinge roller.
Plus if you look in the parts book there is no nylon part in this area except the roller. Maybe you have a picture of the nylon insert you mention? I still learn things about 914s every day no nylon insert at any time from the factory, metal to metal contact between the shoulder bolt and the trunk hinge just grease. George its hard to tell from your pic but do those have the nylon insert like the OE ones? Oh Contrair! I can show you pics of several that come straight off an unmolested car. They did come with a nylon insert like the shift rod coupler cone screws. |
Dec 20 2018, 09:45 AM
I have some NOS ones, I'll check them out and post
mb911 |
Dec 20 2018, 11:12 AM
914 Guru Group: Members Posts: 6,886 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I have seen them as well. Supposed to act like loctite. It's not a seperate part.
Morph914 |
Dec 20 2018, 11:31 AM
It's hard to see but the ones Oscar sent me have either a dab of thread lock or a tiny nylon plug.
And being the guy that Oscar is, I also received this from him at no charge. You da man! (IMG:style_emoticons/default/aktion035.gif) k |
Lo-Fi Version | Time is now: 11th June 2024 - 12:13 PM |
