oil pressure switch |
porsche-tom |
Jan 5 2019, 06:55 AM
Member Group: Members Posts: 140 Joined: 7-March 13 From: jensen beach fl Member No.: 15,626 Region Association: None |
I have a pretty decent oil leak coming from or around the oil cooler. I have a new oil cooler with new seals but I think i should replace the oil pressure switch while I am at it. where is the switch located? any tips for replacing the oil cooler?-thanks
Mark Henry |
Jan 5 2019, 08:49 AM
The switch is sort of under the distributor, right above the oil cooler, look for the wire.
I would definitely install a new switch before I messed with the cooler, a lot of the time it is just the switch leaking. |
dr914@autoatlanta.com |
Jan 5 2019, 09:47 AM
914 Guru Group: Members Posts: 7,869 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes like Mark said this one leaks first, to the left rear of the distributor down in the sheet metal hole with a rubber boot on top and a green with red wire connected. If leaking will be loose you can wiggle the top of it, and or have oil around it. Will have to pull off the boot first to inspect
The switch is sort of under the distributor, right above the oil cooler, look for the wire. I would definitely install a new switch before I messed with the cooler, a lot of the time it is just the switch leaking. |
jdamiano |
Jan 5 2019, 03:27 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
yes like Mark said this one leaks first, to the left rear of the distributor down in the sheet metal hole with a rubber boot on top and a green with red wire connected. If leaking will be loose you can wiggle the top of it, and or have oil around it. Will have to pull off the boot first to inspect The switch is sort of under the distributor, right above the oil cooler, look for the wire. I would definitely install a new switch before I messed with the cooler, a lot of the time it is just the switch leaking. Not my post originally but I’m dealing with the same thing. I spoke with George yesterday and asked him to send me some new oil cooler seals. I just took a closer look at the switch and it is wet. Do I have to replace the entire switch or is it a seal? If you see this before you send my cooler seals George send what I need for the switch leak as well. |
Mark Henry |
Jan 5 2019, 05:18 PM
The switch, no seal, easy to replace and they're cheap.
Also get a new boot as they're usually trashed. The switch has a plastic cap pressed in, they last a long time but as they get old they could start to weep. Once one starts weeping it only gets worse. |
Mark Henry |
Jan 5 2019, 05:31 PM
The switch is the same as on any aircooled VW.
Superhawk996 |
Jan 5 2019, 06:15 PM
914 Guru Group: Members Posts: 5,852 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Be careful and hand thread in the new one first before putting a wrench to it. it is a pipe taper and shouldn't take a lot of torque to seal.
The engine on my current project arrived with the oil pressure sensor pre-stripped and leaking heavily and will need to be re-tapped. (IMG:style_emoticons/default/headbang.gif) Oh the things that were done by previous owners! |
Superhawk996 |
Jan 5 2019, 06:16 PM
jdamiano |
Jan 5 2019, 06:21 PM
So it seems I need a larger deep socket then I have. Does anyone know what size I need to fit the switch?
Superhawk996 |
Jan 5 2019, 06:26 PM
porsche-tom |
Jan 6 2019, 06:04 AM
if it pipe thread is any Teflon tape necessary?
Mark Henry |
Jan 6 2019, 09:17 AM
Lo-Fi Version | Time is now: 22nd May 2024 - 10:29 PM |
