Windage Tray Install Tips?, How do you keep seals in place |
BeatNavy |
Jan 24 2019, 01:24 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
As the title says: how do you keep the windage tray seals where they are supposed to be when installing the engine case halves together? Those little buggers don't like to do what they are told. Do you use one of the sealants or some other way to adhere them in place so they don't flop around?
Not the sexiest question of the day, but then I specialize in those... |
Mike D. |
Jan 24 2019, 02:31 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I've used a thick grease to hold them in place.
More recently, and this is a two man job, rubber bands. But you need the second set of hands to pull the rubber bands out while holding the case halves apart just enough... |
BeatNavy |
Jan 24 2019, 04:01 PM
I thought about rubber bands, but didn't think you could remove them. So I guess you just slide the case together just enough to lock the seals in place and then remove the rubber bands?
Ok. I need a second set of hands. Son is back at school. Neighbor not around when I need him. The dogs apparently don't have opposable thumbs (and don't follow directions very well). Looks like my wife gets to get her hands oily again (IMG:style_emoticons/default/smile.gif) Thanks, Mike. (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 01:55 PM |
