Floor Pan Opinions |
sharper |
Jul 14 2003, 05:49 PM
Member Group: Members Posts: 146 Joined: 5-June 03 From: Woodstock, GA Member No.: 789 Region Association: South East States |
I obviously have some rust issues with my floorpan and wanted to get some opions. Basically the entire section under the center tunnel is rusted out and a few other little areas as well. A friend suggested cutting out the rusted areas and then "sandwich" the new floorpan underneath the old. It is a whole lot less prepwork if I just cut out the entire floor and weld in the new. What is everyone's opion on this?
Brad Roberts |
Jul 14 2003, 05:55 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I can see his point...
but I wouldnt consider the job "done well" doing it this way. I know its a lot of work... but if I where to do it for a customer car... I would remove everything completely. What are your options for steel ?? I thought Restoration design sold a center tunnel seperate from the floorpans. B |
TheCabinetmaker |
Jul 14 2003, 05:58 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Cut and weld!!! No "sandwich"!!!! it adds weight, but no strength. Failure to remove even a square mm of rust will
cause it to continue. Remember, rust is a cancer. Remove it all or it will eat you up! |
Jeroen |
Jul 14 2003, 06:57 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
The 914 is "sandwiched" enough as it is... so please, for your own sake and for those who will own the car after you, don't "sandwich" any more.
If you do the job right, you'll only have to do it once and you'll still be happy with it in a couple of years. good luck (IMG:style_emoticons/default/biggrin.gif) cheers, Jeroen |
urbanskater |
Jul 14 2003, 09:37 PM
Newbie Group: Members Posts: 38 Joined: 6-June 03 From: St. Pete, FL Member No.: 795 |
hey i'm working on my floor pans right now. And well sandwhiching is one of the worst ideas. Do it right, it takes a lot of work, my suggestion pay a body shop to do it, besides you cant sandwhich it anyway, it wouldnt fit with all those grooves and what not.
sharper |
Jul 15 2003, 12:55 PM
That settles it. I am going to cut the whole thing out. There is actually way more prep work involved if I don't. Scraping off the undercoating, grinding away surface rust, and painting to prevent future rust will take a whole lot longer than just cutting it out. I already have a complete new floor pan that is ready to go.
Thanks! |
Brad Roberts |
Jul 15 2003, 01:04 PM
Make damn sure you leave a 1/2 inch wide "lip" all the way around.. so you have something to weld too.
B |
Alfred |
Jul 15 2003, 05:36 PM
Unregistered |
Matt914MI |
Jul 15 2003, 11:17 PM
Newbie Group: Members Posts: 37 Joined: 6-February 03 From: Zeeland, MI Member No.: 260 Region Association: None |
I'm kind of in the same place right now...I'm replacing just the rear section on both sides of the pan. I also have to replace the rear section under the center tunnel, but I haven't cut the old out yet. I have some structural issues in the under-battery-tray area and then the Brad Mayeur kit to worry about first. I'll have lots of pics once I get some time to work on it. These 60 hour work weeks really cut down on car work time.
Gint |
Jul 16 2003, 08:18 AM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Do the whole pan. Even if you do get all of the rust out, if the sandwhich area gets any moisture in it at all (it's now a perfect mositure trap), it will rust again.
Lo-Fi Version | Time is now: 6th June 2024 - 09:00 PM |
