sharper
Jul 14 2003, 05:49 PM
I obviously have some rust issues with my floorpan and wanted to get some opions. Basically the entire section under the center tunnel is rusted out and a few other little areas as well. A friend suggested cutting out the rusted areas and then "sandwich" the new floorpan underneath the old. It is a whole lot less prepwork if I just cut out the entire floor and weld in the new. What is everyone's opion on this?
Brad Roberts
Jul 14 2003, 05:55 PM
I can see his point...
but I wouldnt consider the job "done well" doing it this way.
I know its a lot of work... but if I where to do it for a customer car... I would remove everything completely.
What are your options for steel ?? I thought Restoration design sold a center tunnel seperate from the floorpans.
B
TheCabinetmaker
Jul 14 2003, 05:58 PM
Cut and weld!!! No "sandwich"!!!! it adds weight, but no strength. Failure to remove even a square mm of rust will
cause it to continue. Remember, rust is a cancer. Remove it all or it will eat you up!
Jeroen
Jul 14 2003, 06:57 PM
The 914 is "sandwiched" enough as it is... so please, for your own sake and for those who will own the car after you, don't "sandwich" any more.
If you do the job right, you'll only have to do it once and you'll still be happy with it in a couple of years.
good luck
cheers,
Jeroen
urbanskater
Jul 14 2003, 09:37 PM
hey i'm working on my floor pans right now. And well sandwhiching is one of the worst ideas. Do it right, it takes a lot of work, my suggestion pay a body shop to do it, besides you cant sandwhich it anyway, it wouldnt fit with all those grooves and what not.
sharper
Jul 15 2003, 12:55 PM
That settles it. I am going to cut the whole thing out. There is actually way more prep work involved if I don't. Scraping off the undercoating, grinding away surface rust, and painting to prevent future rust will take a whole lot longer than just cutting it out. I already have a complete new floor pan that is ready to go.
Thanks!
Brad Roberts
Jul 15 2003, 01:04 PM
Make damn sure you leave a 1/2 inch wide "lip" all the way around.. so you have something to weld too.
B
Alfred
Jul 15 2003, 05:36 PM
Have you seen
this floor pan replacement video from BugMeVideo?
Alfred
Matt914MI
Jul 15 2003, 11:17 PM
I'm kind of in the same place right now...I'm replacing just the rear section on both sides of the pan. I also have to replace the rear section under the center tunnel, but I haven't cut the old out yet. I have some structural issues in the under-battery-tray area and then the Brad Mayeur kit to worry about first. I'll have lots of pics once I get some time to work on it. These 60 hour work weeks really cut down on car work time.
Gint
Jul 16 2003, 08:18 AM
Do the whole pan. Even if you do get all of the rust out, if the sandwhich area gets any moisture in it at all (it's now a perfect mositure trap), it will rust again.
