'6 flywheel, 2.0 P&C set "Tuna can" sump |
914ltd |
Feb 12 2019, 02:39 PM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
Some interesting odds and ends:
Koni rear shocks, hand tested, even resistance, no air bubbles. $60 SOLD Heater blower for 73-73. tested, includes original clamp and rubber pad. $35 Bursch for 1.7 and 1.8. good, no muffler, add what you want or a straight pipe. $75 SOLD Pair of 1.7 and 1.8 SSI heats. Leak tested, muffler flange getting thin but still OK. $225. pair SOLD Flywheel, 911 1965 thru 1969 and 914/6. Nice friction surface, 2mm wear on the starter ring gear. Porsche allows 2mm cut from this surface for clean up. $175. Set of stock, US 2.0 pistons and cylinders. Minimal wear, these are in great condition for used. Marked as paired sets 1 thru 4. Clean, ring and use. $150 Weltmeister deep sump (tuna can) $45 Small flat rate ship, $7.90 All parts plus ship from 61611. Thanks, Brad Attached image(s) |
v82go |
Feb 12 2019, 02:59 PM
Resident Contrarian Group: Members Posts: 249 Joined: 9-December 04 From: Lakeland, Fl. Member No.: 3,250 |
Hi Brad I will take the shocks, you can pm me shipping to 33809 and paypal info thanks Bob |
Olympic 914 |
Feb 12 2019, 05:41 PM
Group: Members Posts: 1,672 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
will take the Weltmeister deep sump (tuna can)
[edit] pass on the Tuna can, |
porbmw |
Feb 12 2019, 06:00 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Hi Brad
RE SSI heat exchangers. Can you confirm that neither have been bent...ie...I bought a pair from a member, but it appears that the donor car had been hit and bent the flange on one of them, and also the pipe. Have not, despite great effort, been able to get that side to fit on the cylinder head. If they are straight, will buy them, with shipping to 98230 Thanks Paul |
tsvo |
Feb 12 2019, 07:11 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
Second in line for the shocks if they become available.
Mike Moss |
Feb 13 2019, 09:07 AM
I'm new here ... Group: Members Posts: 0 Joined: 20-March 14 From: Livermore,CA Member No.: 17,143 Region Association: None |
I'll take the Bursch. Let me know how much with shipping to Livermore,CA. 94550.
Thanks Mike |
914ltd |
Feb 13 2019, 09:50 AM
I have had a question about the deep sump and the inability to use a screen.
A few circles with a deburring tool and the pick up extension will twist in. It requires modifying the screen but the results should protect from any debris. Brad I have modified these and left the bottom intact after flattening the "lumps" under the pick up. Attached image(s) |
914ltd |
Feb 13 2019, 10:51 AM
Mike Moss |
Feb 13 2019, 05:34 PM
Mike Moss |
Feb 13 2019, 06:20 PM
I'll take the Bursch. Let me know how much with shipping to Livermore,CA. 94550. Thanks Mike Mike, I wanted to be clear this is used but in great shape. the chrome tip looks good also. Brad That's ok with me. Can you post the picture ftom another angle. |
914ltd |
Mar 13 2019, 10:24 AM
911 flywheel, tuna can still available |
Lo-Fi Version | Time is now: 28th May 2024 - 02:25 PM |
