1974 2.0 in a 73’ 1.7? |
MiniStevieG |
Feb 20 2019, 08:18 PM
Member Group: Members Posts: 179 Joined: 25-January 19 From: Dallas, TX Member No.: 22,827 Region Association: Southwest Region |
Found a rebuilt 2.0. Engine code is a GA so if my research proves accurate this is actually a 74’ engine. Confirmed 3 bolt pattern on the intake heads. Stoked!! I’m curious if this will drop right into my 73’ that’s currently a 1.7 and what I might be in for with this? Headers and heat exchangers? Just a note: per the owner that rebuilt the engine it hasn’t been run since the rebuild so needless to say I need to learn more about what all needs to happen prior to dropping this in and firing it up. Considering taking it to Mayo Performance in Dallas to handle the swap but I’m also a fast learner and eager to do it myself.
Thanks!! |
oldschool |
Feb 20 2019, 09:09 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
bbrock |
Feb 20 2019, 09:25 PM
If it comes with the engine tins, I think it should plug right in. Only thing I can think of is that you'll need to reroute your accelerator cable for the carbs. I'd also make sure it was rebuilt with a carb cam to work well with the Webers.
You will love that engine. BTW, does your car have sway bars? I think at least a front bar is a must-have to get the joy out of that engine. |
MiniStevieG |
Feb 20 2019, 09:52 PM
If it comes with the engine tins, I think it should plug right in. Only thing I can think of is that you'll need to reroute your accelerator cable for the carbs. I'd also make sure it was rebuilt with a carb cam to work well with the Webers. You will love that engine. BTW, does your car have sway bars? I think at least a front bar is a must-have to get the joy out of that engine. Mine does not have sway bars. |
bbrock |
Feb 21 2019, 12:27 PM
I'm surprised you haven't gotten more replies to this thread. Looks like you removed the pic that was here last night, but it looked like you would just need to transfer the cooling fan, housing and front tin from your existing engine to that one and you'd be good to go as long as the rebuilder knew what they were doing.
On the sway bars, I drove two different 1.7 cars for several years before buying the 2.0 I have now. The 2 felt like a completely different animal but I'd say the sway bars contributed as much to the difference as the engine. Great combo. I've always run the factory bars front and rear and loved the handling. I've read that the rear bar doesn't contribute as much to the handling and some people prefer to run without the rear bar. I have no experience with that though. I can only say that a 2.0 with factory bars will make you smile. |
TravisNeff |
Feb 21 2019, 12:49 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
If the engine is complete with tins it will drop right in. no modifications needed. you can even use your 1.7 exhaust system if you like.
MiniStevieG |
Feb 21 2019, 01:20 PM
I'm surprised you haven't gotten more replies to this thread. Looks like you removed the pic that was here last night, but it looked like you would just need to transfer the cooling fan, housing and front tin from your existing engine to that one and you'd be good to go as long as the rebuilder knew what they were doing. On the sway bars, I drove two different 1.7 cars for several years before buying the 2.0 I have now. The 2 felt like a completely different animal but I'd say the sway bars contributed as much to the difference as the engine. Great combo. I've always run the factory bars front and rear and loved the handling. I've read that the rear bar doesn't contribute as much to the handling and some people prefer to run without the rear bar. I have no experience with that though. I can only say that a 2.0 with factory bars will make you smile. Good advice and I'll definitely be looking into sway bars. Not sure what the deal was with the pics I had posted last night. I removed them to reduce file size and thought I added them back but it was late haha. Here's a few pics of the 2.0. I'm told it was rebuilt to 2056cc. |
Mikey914 |
Feb 21 2019, 01:51 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Hey while it’s to this point check the oil cooler seals and oil cooler. Much easier now than later. Other than that you should be able to figure it out. Not that hard, but will require patience.
On another note, looks like 44s ? They will work, but a re a little big for stock 2.0. May have some jetting to do. Is the cam stock?. I would suspect that it may have been changed out if built specifically for carbs. If not run it and look for a deal on a stock injection system. They pop up from time to time. They really run well and if the cam hasn’t been swapped it’s pretty straight forward. Best wishes and please post lots of pics (IMG:style_emoticons/default/biggrin.gif) |
MiniStevieG |
Feb 21 2019, 03:01 PM
Hey while it’s to this point check the oil cooler seals and oil cooler. Much easier now than later. Other than that you should be able to figure it out. Not that hard, but will require patience. On another note, looks like 44s ? They will work, but a re a little big for stock 2.0. May have some jetting to do. Is the cam stock?. I would suspect that it may have been changed out if built specifically for carbs. If not run it and look for a deal on a stock injection system. They pop up from time to time. They really run well and if the cam hasn’t been swapped it’s pretty straight forward. Best wishes and please post lots of pics (IMG:style_emoticons/default/biggrin.gif) Thanks for the tip. All seals were replaced on the engine. It has a CB Performane Road Cam. |
Literati914 |
Feb 21 2019, 07:21 PM
Senior Member Group: Members Posts: 1,475 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Hey Stevie.. welcome, always nice to get another 914 in the metroplex! Hope we can meet up at some point soon. Let my knee heal and I'm all in for assisting in any way I can with your project. Our cars are gonna have a bit in common... Greens w/2056 & stock fuchs. Btw, just curious about where you sourced the engine? I keep my eye open around here and have seen no such rebuilt engine. Good luck with your project!!
MiniStevieG |
Feb 21 2019, 10:12 PM
Hey Stevie.. welcome, always nice to get another 914 in the metroplex! Hope we can meet up at some point soon. Let my knee heal and I'm all in for assisting in any way I can with your project. Our cars are gonna have a bit in common... Greens w/2056 & stock fuchs. Btw, just curious about where you sourced the engine? I keep my eye open around here and have seen no such rebuilt engine. Good luck with your project!! Hey man nice to meet you. Would love to hang out some time for some car talk. One thing’s for sure I could definitely use all the help I can get. I’m in way over my head! New to the 914 world and always wanted one since I was a kid. Anyway, yes about the engine. I jump on deals quick and saw an ad for a 914 here that appeared to be a good donor car. As luck would have it the owner had recently pulled the engine and rebuilt it. He lost interest due to other projects and I snatched it up. Hopefully it turns out to be a winner and sounds nice too when it gets hooked up to a new Triad Exhaust. Let me know when that knee heals up and we can grab coffee sometime or maybe you’d be willing to come turn some wrenches. Now that I’ve secured this new power plant I’m strongly considering stripping my z-green 914 down and starting a fresh build and addressing some of the rust issues underneath as well. Maybe you can help me track down a good welder/fabricator in the area? Cheers!! |
MiniStevieG |
Feb 23 2019, 09:38 PM
Hey Stevie.. welcome, always nice to get another 914 in the metroplex! Hope we can meet up at some point soon. Let my knee heal and I'm all in for assisting in any way I can with your project. Our cars are gonna have a bit in common... Greens w/2056 & stock fuchs. Btw, just curious about where you sourced the engine? I keep my eye open around here and have seen no such rebuilt engine. Good luck with your project!! Back home after 8 long hours in the car picking up a freshly rebuilt 2056cc 2.0 and donor car. The donor car was originally a 75’ color code L80E light ivory. It was going to be my parts car of course but there’s something special about this one. I’m gonna need a bigger shop. |
KELTY360 |
Feb 23 2019, 10:30 PM
914 Neferati Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
I’m gonna need a bigger shop. (IMG:style_emoticons/default/av-943.gif) Famous last words. No matter how big the shop, it needs to be bigger. BTW, nice find. |
Literati914 |
Feb 24 2019, 12:52 AM
Back home after 8 long hours in the car picking up a freshly rebuilt 2056cc 2.0 and donor car. The donor car was originally a 75’ color code L80E light ivory. It was going to be my parts car of course but there’s something special about this one. I’m gonna need a bigger shop. Wow, you've got the bug like the rest of us!! I had two of em until a few months back too. Id bought a real project, had it shipped to Dallas... then a better one popped up locally, and for less money. But nice score there.. so what's the plan now ? |
TheCabinetmaker |
Feb 24 2019, 07:59 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Just for your information. Any year or size 914 engine will fit in any year car. The difference is the intake, exhaust, and induction system. Your research is a bit off. GA engines came in 73 and 74 model years.
MiniStevieG |
Feb 24 2019, 09:09 AM
Just for your information. Any year or size 914 engine will fit in any year car. The difference is the intake, exhaust, and induction system. Your research is a bit off. GA engines came in 73 and 74 model years. Thank you. I am aware that GA engines came from both 73’ and 74’. I was referring to this particular engine code GA012038 according to P914.com |
MiniStevieG |
Mar 5 2019, 01:07 AM
Back home after 8 long hours in the car picking up a freshly rebuilt 2056cc 2.0 and donor car. The donor car was originally a 75’ color code L80E light ivory. It was going to be my parts car of course but there’s something special about this one. I’m gonna need a bigger shop. Wow, you've got the bug like the rest of us!! I had two of em until a few months back too. Id bought a real project, had it shipped to Dallas... then a better one popped up locally, and for less money. But nice score there.. so what's the plan now ? Got the 73’ up on crib stands and gave it a good look. The rust around the floor pan is pretty bad and I’m considering picking up some new replacements and welding them in. Discovered a problem though. As you can see there are crossbars that we’re welded in ugh!! Don’t suppose that’s common? While I don’t mind the extra support it appears it’s going to get in the way of the floor pan replacement. Thoughts on this debacle? Front to back: Front welded cross brace: Rear welded cross brace: Now I’ve got some decisions to make. |
rjames |
Mar 5 2019, 02:10 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Get rid of all of the crossbars and weld a new pan in, bracing the car ahead of time. Or get another car that's a better starting point as it might be cheaper in the long run. Given the shape that the floor pan is in, I imagine there will be other rust areas to deal with like the suspension console and ears.
rhodyguy |
Mar 5 2019, 02:15 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Remove the rocker covers and inspect.
MiniStevieG |
Mar 5 2019, 02:55 PM
Lo-Fi Version | Time is now: 9th June 2024 - 11:09 PM |
