Identifiy these parts, Part ID |
Cornerlot |
Feb 23 2019, 10:28 PM
Member Group: Members Posts: 89 Joined: 4-June 16 From: New Braunfels, TX Member No.: 20,070 Region Association: Southwest Region |
mark04usa |
Feb 23 2019, 10:49 PM
'70 1.7 Tangerine Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region |
91142320503 clutch cable clevis for cable end at trans
91433153305 intermediate plate for rear suspension outboard mount. |
Blue6 |
Feb 23 2019, 10:52 PM
Senior Member Group: Members Posts: 1,035 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
The L brackets are alignment shims for the rear susp. Sorry, don’t recognize the blk plastic thingy...
pilothyer |
Feb 24 2019, 12:47 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
rgalla9146 |
Feb 24 2019, 07:29 AM
Advanced Member Group: Members Posts: 4,563 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Olympic 914 |
Feb 24 2019, 09:08 AM
Group: Members Posts: 1,673 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Clutch cable end.
Looks similar but not it. Don't know what the black plastic part is but the clutch cable end is made of metal and shaped differently. I wouldn't use a plastic part there. You could end up stuck somewhere with no clutch Although the DAPO did use a big wingnut instead of the correct part and it worked for a while. Glad I found that before it stuck me. |
bbrock |
Feb 24 2019, 10:20 AM
Clutch cable end. Looks similar but not it. Don't know what the black plastic part is but the clutch cable end is made of metal and shaped differently. I wouldn't use a plastic part there. You could end up stuck somewhere with no clutch Although the DAPO did use a big wingnut instead of the correct part and it worked for a while. Glad I found that before it stuck me. The original clutch trunions were black plastic like the part in question. That is definitely what that part is. Most have been replaced with metal because the plastic ones break and leave you stranded just like you predict. Ask me how I know... |
Cornerlot |
Feb 24 2019, 10:47 AM
Thanks everyone. Case closed!
Steve |
mepstein |
Feb 24 2019, 10:55 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Clutch cable end. Looks similar but not it. Don't know what the black plastic part is but the clutch cable end is made of metal and shaped differently. I wouldn't use a plastic part there. You could end up stuck somewhere with no clutch Although the DAPO did use a big wingnut instead of the correct part and it worked for a while. Glad I found that before it stuck me. The original clutch trunions were black plastic like the part in question. That is definitely what that part is. Most have been replaced with metal because the plastic ones break and leave you stranded just like you predict. Ask me how I know... (IMG:style_emoticons/default/agree.gif) what a stupid place to use plastic. |
StarBear |
Feb 24 2019, 05:14 PM
Senior Member Group: Members Posts: 1,906 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
REALLY impressed with you guys (and everyone in 914World). My wife doesn't believe me there are this many folks and posts. Amazing...
Dave_Darling |
Feb 25 2019, 05:36 PM
The original clutch trunions were black plastic like the part in question. That is definitely what that part is. Most have been replaced with metal because the plastic ones break and leave you stranded just like you predict. Ask me how I know... Absolutely! The metal one is from a 911, not a 914. Notice that the plastic is longer than the metal trunnion; this is one of the reasons that you need a spacer on the cable when you use the metal trunnion. --DD |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:30 AM |
