Push rod retainers, Reusable? |
krazykonrad |
Mar 18 2019, 10:01 AM
Senior Member Group: Members Posts: 1,127 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Should I be reusing my push rod retainers? If not, who has them?
Thanks! Konrad |
dr914@autoatlanta.com |
Mar 18 2019, 10:03 AM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Mark Henry |
Mar 18 2019, 12:51 PM
If they're bent tweak them with heavy needle nose pliers, many I see the ears are bent.
I don't worry about if they're sitting right in the PR tube when cranking the rocker nuts down, I use smaller needle nose pliers to pull them up afterwards. This is also a must do inspection, they can be off center, but both wire corners should be engaged in each tube. Common to see a shine where an errant wire was running on the PR. |
Lo-Fi Version | Time is now: 31st May 2024 - 11:31 PM |
