| Dion |
Mar 29 2019, 07:18 AM
RN ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region
Hey guys most of the diagrams I see on the 914-6 fuel system
always seem to stop where I want some detail. (IMG:style_emoticons/default/confused24.gif) I just purchased some fuel rail clips and would like to buy the retro fuelrail 914rubber makes. I wanted to see from the point of the fuel rail to the carbs how those lines are situated and the clips and such. Pix of the rear portion of engine bay area and carbs. If anyone has pix would like to see them. I could not find any in the originality forum. I’ll be running Weber’s with no stock airbox though. I’m trying to present as near factory layout as possible. (ie. No aftermarket shiny metallic lines) Thanks fellas! (IMG:style_emoticons/default/beerchug.gif) |
| johnlush |
Mar 29 2019, 11:39 AM
What's all this then? ![]() ![]() Group: Members Posts: 376 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,108 Region Association: Rocky Mountains
The engine's currently out of my /6 so I could get some pictures of the rear bulkhead showing the location of the clip holes and the hard line position if that would be helpful.
| Dion |
Mar 29 2019, 11:49 AM
Appreciate it Josh. I understand where the fuel rail sits, just wondering how the lines come forward to Carbs. Any other clips or do they just rest on the tin & fan shroud as they make their way to the banjo fitting on Carbs. Thanks.
| fixer34 |
Mar 29 2019, 03:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,426 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
The fuel rail on mine has a couple tie wraps holding it to the rear trunk torsion bars (probably not factory..) The fuel hose from the banjo fittings to the rail are black rubber, I think I replaced them years ago and cut to length. Back on the firewall are 3-4 small holes that look they might be used for clips, but I don't ever recall removing them.
| Dion |
Mar 29 2019, 04:09 PM
@fixer34 thank you. Ok. I have the clips for the holes you referenced.
I think I’ll purchase 914rubber’s fuel rail. So it’s basically a straight shot from the rail to the banjo fittings it seems. Appreciate it. Cheers, Dion |
| rgalla9146 |
Mar 29 2019, 05:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,958 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Hey Dion
This is near stock for the fuel line arrangement, The fuel filter is not original but necessary. The clear bottle is my catch can.....as simple as possible. I just noticed one of the fuel line clips is on the loose. Attached thumbnail(s) |
| rgalla9146 |
Mar 29 2019, 05:27 PM
nother
| rgalla9146 |
Mar 29 2019, 05:29 PM
last
| Dion |
Mar 29 2019, 05:30 PM
(IMG:style_emoticons/default/beerchug.gif) Nice, Thanks Rory! That’s perfect.
| gms |
Mar 29 2019, 06:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,746 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest
| sixnotfour |
Mar 29 2019, 06:17 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,214 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
He will be sorry, its a vent, go to air cleaners , or kn that will make white black.. evacuation...its a dry sump,,,unless uour engine is totally Fd, and you know how to check oil level,, you will never need a tank.. or do a proper gt style.. my 2.0 906 plus ,,,pukes a bit at 8500rpm |
| porschetub |
Mar 30 2019, 01:36 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,091 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I didn't use my metal pipe but would rather have,I couldn't seem to set it up because of my regulator placement and the need to read my pressure gauge,I do plan in the future to build a custom hard pipe and minimize the amount of hose used.
Are the holes for the plastic clips drilled in on a 4 cyl or just the factory 6 cyl cars ?. |
| mb911 |
Mar 30 2019, 01:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,759 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
@Dion why not just a recirculation fuel line setup like PMO does?
| rgalla9146 |
Mar 30 2019, 06:48 PM
He will be sorry, its a vent, go to air cleaners , or kn that will make white black.. evacuation...its a dry sump,,,unless uour engine is totally Fd, and you know how to check oil level,, you will never need a tank.. or do a proper gt style.. my 2.0 906 plus ,,,pukes a bit at 8500rpm My other 6 has had this arrangement for many years. The bottle is slit along the top surface so it would vent easily ......if it had any blowby Evacuation ? ...please explain. Not sure if my engine is totally Fd or not. Is totally Fd good or bad ? I do know how to check the oil level. I will always need a tank. Proper GT style ? Early 911 washer bottle in trunk ....original but not exactly elegant. My car is not original My engine will never see 8500rpm You own a 906 ? Attached thumbnail(s) |
| Larmo63 |
Mar 30 2019, 06:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
My 911 washer bottle just rests below the oil tank filler. I use a 914 door vent (the round black thingy with the ball of cotton on it) as a "stopper" for the vent, works like a charm.
Dang Rory, your car is looking great!!!!! |
| Dion |
Mar 30 2019, 07:01 PM
@mb911 I’m prolly going to do a combo of the two, at least in my head. Trying to figure out layout and where regulator like @porschetub has mentioned. I wasn’t sure how close the feed lines sat once the engine is in situ. It’ll be a hybrid of factory and PMO. Most was curious of placement of original setup (IMG:style_emoticons/default/beerchug.gif) |
| rgalla9146 |
Mar 30 2019, 07:02 PM
My 911 washer bottle just rests below the oil tank filler. I use a 914 door vent (the round black thingy with the ball of cotton on it) as a "stopper" for the vent, works like a charm. Dang Rory, your car is looking great!!!!! Thank you Lawrence........yep, never seen snow.... |
| porschetub |
Mar 31 2019, 12:13 AM
He will be sorry, its a vent, go to air cleaners , or kn that will make white black.. evacuation...its a dry sump,,,unless uour engine is totally Fd, and you know how to check oil level,, you will never need a tank.. or do a proper gt style.. my 2.0 906 plus ,,,pukes a bit at 8500rpm My other 6 has had this arrangement for many years. The bottle is slit along the top surface so it would vent easily ......if it had any blowby Evacuation ? ...please explain. Not sure if my engine is totally Fd or not. Is totally Fd good or bad ? I do know how to check the oil level. I will always need a tank. Proper GT style ? Early 911 washer bottle in trunk ....original but not exactly elegant. My car is not original My engine will never see 8500rpm You own a 906 ? (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) great answer to a very strange reply,well done (IMG:style_emoticons/default/beerchug.gif) |
| sixnotfour |
Mar 31 2019, 02:28 AM
QUOTE Evacuation ? ...please explain. opening, purging, drainage 906 plus spec even a -6 air cleaner has a drain Ill leave it with GMS "Nice puke tank" |
| Cairo94507 |
Mar 31 2019, 08:19 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,622 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Rory, Larmo nailed it- your car is beautiful; love the RS finish wheels too. The look is perfect. (IMG:style_emoticons/default/smilie_pokal.gif)
Lo-Fi Version | Time is now: 1st May 2026 - 08:19 AM |
