-6 Remote Cooler Thermostat and Lines |
roblav1 |
Apr 7 2019, 06:31 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
-6 Build: Where are people installing the remote oil cooler thermostat? I want to weld in a bracket for it before paint. Kindof new to me since we never use remote oil thermostats in our formula racecars.
I was debating putting it on the right side - to run the oil out from the pump outlet in the case on the right side - to the thermostat, then split with one line going to the tank and the other to the cooler. It almost makes sense to run the feed line to the cooler on the right side and the return line from the cooler to the tank on the left side. But what confuses me is why does the oil thermostat have four ports instead of three? With three, one inlet port from the engine, one outlet port to the tank, and the other outlet port to the cooler. Where does the fourth port come into play? Thanks, Rob |
mb911 |
Apr 7 2019, 06:46 PM
914 Guru Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
roblav1 |
Apr 7 2019, 06:50 PM
Perfect! Thank you again!
I forgot that the tank has only one fitting for the return oil! Hence the need for a 4 port thermostat. |
mepstein |
Apr 7 2019, 06:51 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I ran my outlet up the right and return down the left.
Unless I have it wrong, the thermostat has a valve in the middle that opens when the oil heats it up. Until then, oil goes in the thermostat and is redirected 180 degrees. When it opens it goes strait through on each side. Attached image(s) |
roblav1 |
Apr 7 2019, 09:58 PM
Thanks Mark.
Lo-Fi Version | Time is now: 9th June 2024 - 10:11 PM |
