oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,372 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I think we used to order then from Automotion but that was a long time ago.
I have a metal one that is damaged (it stuck and the spring wore a flat spot) and needed replacing so I just ordered a set of plastic ones from 914rubber. I'll look to see if I still have the other metal one from the other side that was not damaged. If I have it you are welcome to it free of charge. Jim |
oakdalecurtis |
I think we used to order then from Automotion but that was a long time ago. I have a metal one that is damaged (it stuck and the spring wore a flat spot) and needed replacing so I just ordered a set of plastic ones from 914rubber. I'll look to see if I still have the other metal one from the other side that was not damaged. If I have it you are welcome to it free of charge. Jim Thanks JC, will wait to see if you find it... |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,904 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
I think I have a set but I may not be able to look for them till next week.
jcd914 |
I found them.
You can see one is worn badly, PO forced on to a hinge pin that was already worn from the spring rubbing the pin directly with no roller at all. I will probably replace the hinge before I install the plastic rollers I got from 914rubber. Curtis, PM me a mailing address and I'll send the good one. Thanks Jim PS, my sister, brother in law and nephew live in Oakdale. ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Yes these are a sacrificial part and they do wear. Even the metal ones. The delrin still holds up well too.
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,219 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Could easily be duplicated manually on a lathe for about 1hr with of machinist time. I’m surprised someone isn’t doing these in bulk via CNC for sale.
Mikey914 |
Attached thumbnail(s) ![]() Attached image(s) ![]() |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,777 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
These have been on my car for 30 plus years.
Don't know where they came from. Based on design and lifespan this should be the prototype for any new product. I'll gladly provide info to any maker. Attached thumbnail(s) ![]() ![]() |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,187 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
we never sold the metal ones nor brass as they wear out the trunk torsion rod. Always the delrin plastic, have PLENTY of them on the shelf at all times if you cannot find one anywhere, please make sure you install with grease and lube the shoulder bolt where it pivots on the trunk hinge to avoid a costly failure of the cup
Lo-Fi Version | Time is now: 11th July 2025 - 12:10 PM |
