need pic of oil lines through fuel tank compartment, trying to figure out where holes need to go |
buck toenges |
May 2 2019, 08:24 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I am in need to see where people are placing holes in the fuel tank compartment for oil lines when installing a front oil cooler. Here is my fuel tank compartment. Some people are running the oil lines in the channel. My question is if this is the location how do you drill a hole from inside the channel to the main cabin?
Thanks, Buck |
buck toenges |
May 5 2019, 04:01 PM
I found a picture of a 914-6 gt build. It is from inside the cabin by the foot pedal assembly. The picture is of a oil line coming through the firewall. It looks like it corresponds to the channel in the above pic that I posted. Is there an actual hole through the fire wall already in the 914? Since I can not see very well on my car in the foot well position I can only guess that there is one already and you don't have to cut out any metal in the fire wall. Can anybody verify? If you have to cut out metal to make access through the fire wall how do you do it? Seems like an impossible task if there isn't a hole already.
Thanks, Buck Attached image(s) |
mb911 |
May 5 2019, 08:26 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Buck
I thought you had this figured out it really is that easy. The spot you have outlined is the channel you would see hoses running through there.. They do not pop out of that opening though. The holes you cut already in the foot well leads there and then hits a brick wall which is the very front bulkhead. You drill that from the front trunk. It will be an odd shape opening but you can make it happen. Look at the very right of my picture right by the trunk floor. That's the second hole and you snake the soft oil lines through there. |
buck toenges |
May 6 2019, 12:00 PM
I didn't realize the channel goes through the bulk head into the cabin. I thought there was metal between the cabin bulk head and the channel. Just like there is metal in the front bulk head and channel that I had to cut out to snake the oil lines to the front cooler. I assumed that the channel was blocked off at the bulk head to the cabin.
Buck |
sixnotfour |
May 6 2019, 01:26 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
from 914-6 gt pbase
Attached image(s) |
roblav1 |
May 6 2019, 08:59 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I think the location depends on whether or not you want the lines going through the passenger compartment. I'd rather keep the heat out and run them where the charcoal canister lines went.
Lo-Fi Version | Time is now: 2nd June 2024 - 05:03 AM |
