| jwinner |
May 8 2019, 08:36 PM
Newbie ![]() Group: Members Posts: 23 Joined: 5-August 14 From: Milwaukee, WI Member No.: 17,736 Region Association: Upper MidWest |
Looking for a 6-hole flywheel plate for a 914-6 or 911 flywheel. Please let me know if you have an extra for sale. Thank you, James.
| mepstein |
May 8 2019, 08:45 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,626 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I’m sure I do. I’ll check tomorrow. Mark
| mb911 |
May 8 2019, 08:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,740 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
James you don't need one with ARP fasteners.. It says not to use one in the directions.
| porschetub |
May 8 2019, 10:38 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,079 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Now I'am (IMG:style_emoticons/default/confused24.gif) I used no washer plate but found the factory ($$$) bolts fitted nicely into recess's on the the 911 flywheel I bought,the 914/6 part is different so maybe that's when the plate washer is used....really I don't know,anyone chime in ?.
| mb911 |
May 9 2019, 05:06 AM
Now I'am (IMG:style_emoticons/default/confused24.gif) I used no washer plate but found the factory ($$$) bolts fitted nicely into recess's on the the 911 flywheel I bought,the 914/6 part is different so maybe that's when the plate washer is used....really I don't know,anyone chime in ?. Use the washer with factory bolts don't with ARP.. |
| jwinner |
May 9 2019, 09:07 AM
Now I'am (IMG:style_emoticons/default/confused24.gif) I used no washer plate but found the factory ($$$) bolts fitted nicely into recess's on the the 911 flywheel I bought,the 914/6 part is different so maybe that's when the plate washer is used....really I don't know,anyone chime in ?. Use the washer with factory bolts don't with ARP.. Thanks for the info Ben! I am trying to figure out what wasters, seals, etc we need for the 914 tranny to 911 engine project. |
Lo-Fi Version | Time is now: 14th April 2026 - 06:14 PM |
