| CheeRS |
May 10 2019, 01:08 PM
Member ![]() ![]() Group: Members Posts: 93 Joined: 5-May 19 From: Paris France Member No.: 23,093 Region Association: France |
Hi, here is my presentation post :
http://www.914world.com/bbs2/index.php?showtopic=337989 two weeks ago I was in Monthlery near Paris France, for a wagenfest with my 914. Get some troubles with the engine, a hammer noise and the engine stopped smoothly like out of gas. here is what I found : https://drive.google.com/open?id=1gzsWwNBOh...86Kbof2P4BCHHrm some pics |
| CheeRS |
May 10 2019, 01:20 PM
my own workshop, this is a Aircooled specialized self garage
Attached thumbnail(s) |
| CheeRS |
May 10 2019, 01:21 PM
cylinder 3 admission valve stand in open position
| CheeRS |
May 10 2019, 01:29 PM
Opening the engine and disassembling the djetronic I found somme stranges things I will like to show you
question #1 : the head temperature sender was not plugged, perhaps I unplugged it myself by mistake. where does it plug ? Attached thumbnail(s) |
| 914_teener |
May 10 2019, 01:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,268 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
classic dropped valve seat.
Pull the heads and redo them. |
| 914_teener |
May 10 2019, 01:33 PM
| CheeRS |
May 10 2019, 02:07 PM
Opening the engine and disassembling the djetronic I found somme stranges things I will like to show you question #1 : the head temperature sender was not plugged, perhaps I unplugged it myself by mistake. where does it plug ? Plugs into the ecu wiring harness. I agree but where ? here ? Attached thumbnail(s) |
| 914_teener |
May 10 2019, 02:30 PM
Follow the ecu harness back from the ECU...you should see a wire with a plastic connector shield on the end of the lead. Usually the wire is white like the one I see in the picture.
| CheeRS |
May 10 2019, 02:55 PM
Thanks, to be sure I will track the wire and the number in the ECU connector.
Another part was not plugged, the additionnal air valve. Attached thumbnail(s) |
| GregAmy |
May 10 2019, 06:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,604 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
I'd be more worried about the dropped valve seat before where the wires plug in...but that's just me...
| bandjoey |
May 10 2019, 06:11 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
For a guy with that shop, I don't think he worries about wires or seats. (IMG:style_emoticons/default/first.gif)
| Chi-town |
May 10 2019, 07:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Have the head checked for cracks before you waste time / money in machine work putting a seat back in it.
Look in the exhaust seat to the plug |
| Dave_Darling |
May 10 2019, 08:46 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,298 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
After you look at the heads, consider the LN series heads from the Type 4 store, or if you have a good machinist locally consider getting new head castings from AMC in Spain and using them as cores.
It might make more sense to repair yours, but new castings are available. --DD |
| CheeRS |
May 11 2019, 12:42 AM
I'd be more worried about the dropped valve seat before where the wires plug in...but that's just me... Thanks friends, you are right. I checked the head, saw no scratch, I will check again after cleaning. Next week, I will give the head to a specialised shop http://www.rectif2000.com/ This is why I already thinking about the engine reassembly. Djetronic works fine but is complicated. A pic of my selfgarage near Paris named Atelier M8 Attached thumbnail(s) |
| CheeRS |
May 11 2019, 12:43 AM
more
| Bleyseng |
May 11 2019, 08:43 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
If I were you I'd order a set of new castings set up by Len at HAM for replacing those. I just did mine with a set from him including having bigger valves installed (44x38). Well worth every penny!
| rhodyguy |
May 11 2019, 08:56 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Do you intend just to do the one head?
| Bleyseng |
May 11 2019, 09:57 AM
Buy a set of these with the coating to keep the heat out of the head.
| CheeRS |
May 11 2019, 06:36 PM
If I were you I'd order a set of new castings set up by Len at HAM for replacing those. I just did mine with a set from him including having bigger valves installed (44x38). Well worth every penny! To keep the race passport available, I need to keep the engine stock specs. |
| CheeRS |
May 11 2019, 06:38 PM
Lo-Fi Version | Time is now: 7th December 2025 - 07:54 PM |
