CheeRS
May 10 2019, 01:08 PM
Hi, here is my presentation post :
http://www.914world.com/bbs2/index.php?showtopic=337989two weeks ago I was in Monthlery near Paris France, for a wagenfest with my 914.
Get some troubles with the engine, a hammer noise and the engine stopped smoothly like out of gas.
here is what I found :
https://drive.google.com/open?id=1gzsWwNBOh...86Kbof2P4BCHHrmsome pics
CheeRS
May 10 2019, 01:20 PM
my own workshop, this is a Aircooled specialized self garage
CheeRS
May 10 2019, 01:21 PM
cylinder 3 admission valve stand in open position
CheeRS
May 10 2019, 01:29 PM
Opening the engine and disassembling the djetronic I found somme stranges things I will like to show you
question #1 :
the head temperature sender was not plugged, perhaps I unplugged it myself by mistake.
where does it plug ?
914_teener
May 10 2019, 01:30 PM
classic dropped valve seat.
Pull the heads and redo them.
914_teener
May 10 2019, 01:33 PM
QUOTE(CheeRS @ May 10 2019, 12:29 PM)
question #1 :
Plugs into the ecu wiring harness.
CheeRS
May 10 2019, 02:07 PM
QUOTE(914_teener @ May 10 2019, 01:33 PM)
question #1 :
I agree but where ?
here ?
914_teener
May 10 2019, 02:30 PM
Follow the ecu harness back from the ECU...you should see a wire with a plastic connector shield on the end of the lead. Usually the wire is white like the one I see in the picture.
CheeRS
May 10 2019, 02:55 PM
Thanks, to be sure I will track the wire and the number in the ECU connector.
Another part was not plugged, the additionnal air valve.
GregAmy
May 10 2019, 06:00 PM
I'd be more worried about the dropped valve seat before where the wires plug in...but that's just me...
bandjoey
May 10 2019, 06:11 PM
For a guy with that shop, I don't think he worries about wires or seats.
Chi-town
May 10 2019, 07:02 PM
Have the head checked for cracks before you waste time / money in machine work putting a seat back in it.
Look in the exhaust seat to the plug
Dave_Darling
May 10 2019, 08:46 PM
After you look at the heads, consider the LN series heads from the Type 4 store, or if you have a good machinist locally consider getting new head castings from AMC in Spain and using them as cores.
It might make more sense to repair yours, but new castings are available.
--DD
CheeRS
May 11 2019, 12:42 AM
QUOTE(GregAmy @ May 10 2019, 06:00 PM)
Thanks friends, you are right.
I checked the head, saw no scratch, I will check again after cleaning.
Next week, I will give the head to a specialised shop
http://www.rectif2000.com/This is why I already thinking about the engine reassembly.
Djetronic works fine but is complicated.
A pic of my selfgarage
near Paris named Atelier M8
CheeRS
May 11 2019, 12:43 AM
more
Bleyseng
May 11 2019, 08:43 AM
If I were you I'd order a set of new castings set up by Len at HAM for replacing those. I just did mine with a set from him including having bigger valves installed (44x38). Well worth every penny!
rhodyguy
May 11 2019, 08:56 AM
Do you intend just to do the one head?
Bleyseng
May 11 2019, 09:57 AM
Buy a set of these with the coating to keep the heat out of the head.
CheeRS
May 11 2019, 06:36 PM
QUOTE(Bleyseng @ May 11 2019, 08:43 AM)
To keep the race passport available, I need to keep the engine stock specs.
CheeRS
May 11 2019, 06:38 PM
QUOTE(rhodyguy @ May 11 2019, 08:56 AM)
I will ask to the machining shop to check each valves, then will see.
CheeRS
QUOTE(Bleyseng @ May 11 2019, 09:57 AM)
A adress to have a quote and check if there is shipping in France ?
BeatNavy
May 11 2019, 06:47 PM
https://newsite.hamheads.com/home/Contact Len Hoffman using that link.
Jetsetsurfshop
May 11 2019, 07:36 PM
Good money spent.
Superhawk996
May 11 2019, 08:22 PM
QUOTE(Dave_Darling @ May 10 2019, 10:46 PM)
--DD
I'm considering options for heads. Checked Type 4 store and it seems they don't list the LN series. Other's looks to be for Transporters? Am I missing something?
Dave_Darling
May 11 2019, 10:15 PM
Sorry, I meant LE series heads.
But they look to be more than just equivalent heads to the 2.0, so they may not work with your class rules.
Still, new AMC castings plus a good machine shop to replace the wear parts (guides, seats, valves, springs, etc.) which aren't great quality on the AMC heads. And I think the AMC heads come from Spain, so you can save some in shipping.
--DD
--DD
porschetub
May 11 2019, 11:58 PM
I would be rather worried about rebuilding those heads considering you use the car in competition events,with constant head cycling they get soft and don't hold the valve seats well ,the exhaust side suffers most for obvious reasons.
For what you will be spending on these old heads the AMC option is the best longterm solution,as far as your class rules go you can buy them with stock valve sizes so you should be fine.
By the way nice workshop and cars WOW.
CheeRS
May 12 2019, 02:21 AM
I had a look on amc spain, 914 heads are not available yet
About head seals, on a french forum, I get the differents responses, with or without head seal between cylinders and head.
seals are on the Porsche PET.
your opinion ?
Superhawk996
May 12 2019, 08:06 AM
QUOTE(CheeRS @ May 12 2019, 04:21 AM)
your opinion ?
Oh no . .. . here we go.
r_towle
May 12 2019, 08:27 AM
no head seal (gasket) needed.
You can lap the cylinders to the heads to get a good seal.
Without that Head Temp Sensor, its possible that you ran too lean.
Thus, you dropped the valve.
Good luck with the new rebuilt heads, they may work out, but using old head tends to be a gamble (one I do all the time)
rich
Mark Henry
May 12 2019, 12:13 PM
You can get new bare 914 2.0 cores from AA performance, they come with nothing, no seats, guides hardware etc. IIRC they do come with the exhaust studs.
They would need to be sent to a machine shop, you have to use 8mm stem exhaust valves and guides.
sithot
May 12 2019, 02:24 PM
QUOTE(CheeRS @ May 11 2019, 08:36 PM)
When did people stop cheating? Sand bagging is ALWAYS an option.
Bleyseng
May 12 2019, 03:51 PM
QUOTE(Mark Henry @ May 12 2019, 11:13 AM)
This is the route I took with Len to make my set.
CheeRS
May 12 2019, 04:51 PM
QUOTE(r_towle @ May 12 2019, 08:27 AM)
rich
Bonsoir, what do you mean by lap the cylinder to the head ? (I'm French)
porschetub
May 12 2019, 06:31 PM
QUOTE(CheeRS @ May 13 2019, 10:51 AM)
rich
Use lapping compound same as used for doing inlet and exhaust valves,the sealing rings don't last and are no longer used ,have seen some cause heads to come loose and resulting leakage.
Google VW barrel to head lapping you will find more info as its hard to explain,been doing it on T1 motors for years the 914 motor needs it too.
Good luck.
CheeRS
May 13 2019, 04:19 PM
tomorrow I dismount the second cylinder head and I will take them to the technician.
about cylinders and pistons, they have 30.000kms.
The segments are good but I have the impression that seen from above there is space between cylinder and piston.
Is the top of the piston a bit conical?
30.000 were made in WOT rallye position so could be used.
Which model of pistons and cylinders do you recommend ?
I do not want to machine the block but it is useful to climb a little cubic with the djetronic ?
I'm thinking about a 96mms upgrade.
Regarding the head temperature sender I found the place to plug it, thanks to 914wold community.
CheeRS
May 14 2019, 05:34 AM
the actual pistons are AA 93,95
CheeRS
May 16 2019, 01:44 PM
Bonsoir tout le monde, with your help, thinks are more accurates for me now.
Heats will be fully rebuild by a very good specialised workshop.
New cylinders are not expensive, will be AA perf in 96mms.
New engine and djetronic engine beam, injectors fully checked.
Question : what about a external additional oil heater ?
veltror
May 16 2019, 04:38 PM
Since you are in Europe, just across the water talk to Rainier at Orratech Germany.
CheeRS
May 18 2019, 02:37 PM
Hello, this week, heads will be shipped to the specialised shop.
Cylinders and pistons seem to be good but compare to the price, why not a new set in 96mms ?
Found 3 shops in EU, not sure all are flat pistons.
https://www.mecatechnic.com/fr-FR/kit-cylin...0-l_KD12506.htmor
http://www.slideperformance.com/kit-cylind...bi-karmann.htmlor
https://www.typ4shop.de/Motorteile-Kolben-W...-2-1L::100.htmlAll the wiring questions about Djectronic are done, thanks
CheeRS
May 18 2019, 02:39 PM
Was surprised to found this modification on my engine
CheeRS
May 18 2019, 02:43 PM
this screw is not original.
Why make this ?
Perhaps there is a link with the fact the additional air valve was not pluged, so not available.
But the problem is that the installation unable the WOT thottle position
billh1963
May 18 2019, 03:14 PM
I've seen a picture like that before...
Before my valve seat dropped I noticed my temperatures were running hotter than normal. Once I pulled the engine I noticed the thermostat had failed...and it failed closed! Yes, someone in the past used a the Mexican made type I thermostat that fails closed
CheeRS
May 28 2019, 09:53 AM
Hello,
Heads, pistons and cylinders are at the machinist shop.
Now the long block is fully cleaned and I discovered severals scraches than are crossing the engine.
Some pics
CheeRS
May 28 2019, 09:54 AM
more
CheeRS
May 28 2019, 09:55 AM
Is the block dead ?
CheeRS
May 28 2019, 09:56 AM
last one
CheeRS
May 28 2019, 09:57 AM
with nail we feel an angle so the block has moved
Dave_Darling
May 28 2019, 11:40 AM
We would call those "cracks", not "scratches".
If the cracks get into precisely machined areas, like where the cam and the crank run, the case is junk. If it is important to have that specific case with that specific serial number, a really good machinist can probably cut out the cracks and weld them up, then re-machine everything so it is in spec again.
If the cracks do not run into those areas, there's a very good chance that they will spread into those areas. Again, a very good machinist may be able to drill the ends of the cracks and stabilize everything, but that is probably not going to be a permanent solution.
The damage looks to be around the lifter holes. I would be the most concerned about the camshaft bores, because having one of those move will kill the motor pretty quickly. I wonder if that could be related to the "Type IV Syndrome", where someone over-tightens the nut holding the sump plate onto the bottom of the motor? This can bend one of the through-bolts that the oil pickup hangs from, and crack the case around it. Distressingly common.
If you have access to another case, I would suggest using it. That's the simplest way to move forward. If you do not, either find one or find a really good machinist who can weld and machine the existing case.
--DD
sixnotfour
May 28 2019, 12:09 PM
out side of case,,get a die kit,,,casting flaws ??
ChrisFoley
May 28 2019, 06:37 PM
I see casting lines, not cracks.
