914 613 541 02A back up switch connection, need the "bullet type" connector end |
Str1974 |
May 12 2019, 07:07 PM
Member Group: Members Posts: 90 Joined: 23-January 19 From: Dallas Member No.: 22,820 Region Association: Southwest Region |
I have a question regarding the back-up switch. I needed to replace it because the wiring connectors had broken off right where they plug into the two female connections on the switch (one underneath the back drivers side section of engine). I would have spliced the wire and connectors if I would have any length of wire left. All I have is bare wire and the two female connections. I've been trying to locate the right size bullet connectors that could be hooked up to bare wire, but no luck. The back up switch is easy to locate and purchase, but I cannot locate the male connectors. Any advise?
rudedude |
May 12 2019, 07:20 PM
Senior Member Group: Members Posts: 510 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
I think I've gotten them from stoddard
Str1974 |
May 12 2019, 08:02 PM
Chris914n6 |
May 12 2019, 08:32 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Common bullet connectors work. Might have stretched it out a bit, don't remember.
Bleyseng |
May 12 2019, 09:58 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
bdstone914 |
May 12 2019, 10:25 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Str1974
I got the correct ones from Bel Metric. German made with double crimp on bare wire and insulated wire. I think they were 4mm. https://www.belmetric.com/bullet-connectors...mm-p-11391.html @Bleyseng Attached thumbnail(s) |
IronHillRestorations |
May 13 2019, 07:25 AM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
SAE bullet connectors will work
dr914@autoatlanta.com |
May 13 2019, 08:21 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we always have plenty of the solder in bullets available
Str1974 |
May 13 2019, 10:22 AM
Str1974 |
May 13 2019, 10:24 AM
@Str1974 I got the correct ones from Bel Metric. German made with double crimp on bare wire and insulated wire. I think they were 4mm. https://www.belmetric.com/bullet-connectors...mm-p-11391.html @Bleyseng Wow, you guys are awesome. 914World rocks! I want to thank all you guys for your help. |
Bleyseng |
Jul 30 2019, 12:03 AM
Yes, I picked up some of these so now I just have install them.
mikesmith |
Jul 31 2019, 07:06 PM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
These worked well for me; generic 5mm R/C motor / battery bullet connectors.
https://www.amazon.com/gp/product/B01CQ2OMJE |
JeffBowlsby |
Jul 31 2019, 09:32 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
4.5mm is the correct size for these terminals.
Jul 31 2019, 10:04 PM
I use regular SAE bullet connectors, I just cut them shorter, and crimp and solder them on.
Lo-Fi Version | Time is now: 2nd June 2024 - 12:22 AM |
