Steering column interchangability?, Can I change out my early column for later model. |
deemsriddle |
May 16 2019, 07:06 AM
Newbie Group: Members Posts: 15 Joined: 1-January 17 From: Ringgold GA Member No.: 20,717 Region Association: South East States |
The steering column in my 1971 914 started out with problems starting. The starter would not engage every time but would always start eventually. Now the switch is hung up in the start position. I know that Ii need a new column, but wonder if the columns and interchangeable? The wiring should be doable, but are there any other considerations?
mepstein |
May 16 2019, 09:12 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mine had issues. I found a replacement for the piece that was broken on the turn signal and sent my switch to “tweet” so the key would work properly. There was a little plate on the back of the switch that was broken and it needed cleaning and a new, non worn out key was made. I would repair what you have vs making a Frankenstein steering assembly. Later columns have the wiper on a stalk so adding a late into an early will never look right.
dr914@autoatlanta.com |
May 16 2019, 09:26 AM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the easiest thing to do (although it is not that easy) is to replace the switch.
To change to the later column, you would have to weld brackets into your car and change the wiring harness around. NOT easy NOT fun The steering column in my 1971 914 started out with problems starting. The starter would not engage every time but would always start eventually. Now the switch is hung up in the start position. I know that Ii need a new column, but wonder if the columns and interchangeable? The wiring should be doable, but are there any other considerations? |
deemsriddle |
May 16 2019, 12:08 PM
We got the steering column off and we have had a small fire. I looks like I need another column.
mepstein |
May 16 2019, 12:12 PM
914Sixer |
May 16 2019, 12:21 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Some NOS columns on Ebay and the Samba.com Direct plug and play. NO hassles.
SirAndy |
May 16 2019, 12:22 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
To change to the later column, you would have to weld brackets into your car and change the wiring harness around. NOT easy NOT fun (IMG:style_emoticons/default/agree.gif) I put a '74 steering column and main wiring harness in my '70 car and it was a royal pain in the arse. As the Dr. mentioned, i had to drill, grind and weld the column support under the dash to accept the '74 unit. I also had to customize the steering shaft that goes down to the steering coupler since the attachment points on the column are in a different location and the geometry doesn't work (the u-joints will bind!), i had to shorten the downlink and re-groove the shaft for the bolts to get the correct geometry. The wiring of the column was not problem for me since i also went with a complete '74 main harness. But that in itself was also no simple undertaking. Trying to match the '74 column wiring to a early wiring harness looks like a nightmare since the stock connectors don't match and the wires don't match either. For starters, early cars have the windshield wiper switch on the dash, not on the column. But there's more mismatch. TL:DR Tons of work, not worth it, wouldn't do it again ... (IMG:style_emoticons/default/shades.gif) |
mepstein |
May 16 2019, 12:39 PM
Some NOS columns on Ebay and the Samba.com Direct plug and play. NO hassles. (IMG:style_emoticons/default/agree.gif) pay the money, plug it in, done. good for another 50 years, priceless. |
76-914 |
May 17 2019, 08:07 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You can do it w/o welding but welding would be easier. And yes you'd want to get the appropriate harness. (IMG:style_emoticons/default/agree.gif) with others comments and you'll need to change the dash metal trim piece as well. (IMG:style_emoticons/default/beerchug.gif)
SirAndy |
May 17 2019, 11:18 AM
You can do it w/o welding but welding I don't see how this could be done without welding. The metal sub-frame is different from early to late. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 01:39 AM |
