Rear Wheel Bearing questions |
LCOX |
May 19 2019, 11:08 AM
Member Group: Members Posts: 93 Joined: 19-December 09 From: Pinnacle Member No.: 11,148 Region Association: None |
Need to replace my passenger side rear wheel bearing. I've got the cv axle off the car and the big 30mm nut and inner stub axle that the nut goes on off as well. 2 questions
1. How do you get the outer wheel hub and wheel bearing off the car. Can this be done with the rear control arm still on the car? 2. Once these part are off does the bearing and outer wheel hub have to be pressed in? Do I just need to take the control arm off and get a machine shop to press the old parts out and new ones in? Thnx L |
Dave_Darling |
May 19 2019, 11:54 AM
It does get pressed (or pulled) apart, and pressed together.
It can be done with the trailing arm on the car. Usually by heating the arm and freezing the bearing, and then working quickly. Some prefer to just remove the trailing arm and take it to a press. --DD |
Mike D. |
May 19 2019, 12:08 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Or you can make something like this, I have seen other types. Admittedly, I did not make it. I bought it from someone at a swap. It will remove the old one and instal the new one with trailing arm still on the car.
Attached image(s) |
jim_hoyland |
May 19 2019, 12:34 PM
Get that VIN ? Group: Members Posts: 9,317 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Geezer914 |
May 19 2019, 01:51 PM
Geezer914 Group: Members Posts: 1,440 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
There is an old VW mechanic that shows how to do it on youtube.
914fahrer |
May 19 2019, 01:57 PM
Member Group: Members Posts: 103 Joined: 12-November 14 From: Berlin/Germany Member No.: 18,115 Region Association: Germany |
bbrock |
May 19 2019, 02:48 PM
I have this kit from Harbor Freight. Works great to remove and install rear bearings on my 914 and Honda. https://www.harborfreight.com/front-wheel-b...ters-63728.html
Carl La Fong |
May 19 2019, 03:17 PM
Member Group: Retired Members Posts: 137 Joined: 27-March 19 From: west Member No.: 23,000 Region Association: None |
I have a tool for that and I would send it to you but I don't know where pinnacle is. (IMG:style_emoticons/default/biggrin.gif)
LCOX |
May 20 2019, 09:21 AM
Thanx for all the input. I'm in NC
billium01 |
May 20 2019, 09:34 AM
Member Group: Members Posts: 136 Joined: 12-April 13 Member No.: 15,764 Region Association: None |
76-914 |
May 20 2019, 09:43 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You can make one as shown above but be sure to use a grade 8, fine thread piece. I bought a home made set up that had a course thread and was probably grade 5. It destroyed itself very quickly. Look at the HF model that Brett posted. The very fine thread makes it functional. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 6th June 2024 - 03:03 PM |
