Front windshield, Installation options |
KevinW |
May 26 2019, 07:27 AM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
Searching for options to install my front windshield. Currently it is out and everything is clean (blank slate). I would prefer not to glue it in place. Is there a rubber gasket that you slide the windshield into? The same applies to the rear window.
Thanks Kevin |
Chi-town |
May 26 2019, 07:36 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
The glass actually becomes part of the structure when glued in and helps stiffen the car. When I was younger I had to take a class on glass replacement to be certified by GM and they showed that the glass actually makes a significant difference structural rigidity even though it's only bonded in.
The old rubber "rope in seals" always leak if you don't have buytl in them and it always makes a mess on hot days. |
bdstone914 |
May 26 2019, 09:21 AM
bdstone914 Group: Members Posts: 4,534 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Lo-Fi Version | Time is now: 6th June 2024 - 12:38 PM |
