Logging On to World, Something changed.... |
jim_hoyland |
May 31 2019, 03:30 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
All of a sudden every time I go to open 914World, I have to log on. Doesn’t happen when using iPad or MacBook, just the iPhone. Is there a setting I need to change? Seems like this happened several years ago......
Any help will be appreciated |
jim_hoyland |
May 31 2019, 03:37 PM
And when I manually log on, I get this Not Secure message ????
Attached thumbnail(s) |
SirAndy |
May 31 2019, 03:47 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Make sure you have cookies turned on, otherwise we can't track your login.
As for the "not secure" message, that's because we don't have a SSL certificate so it deems our login page "not secure". I'll get around to fixing that eventually but it isn't really a big deal. (IMG:style_emoticons/default/shades.gif) |
jim_hoyland |
May 31 2019, 04:09 PM
sb914 |
May 31 2019, 04:43 PM
Surf Guru Group: Members Posts: 4,314 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
In the oven! Pre heat to 350 degrees (IMG:style_emoticons/default/poke.gif)
wes |
May 31 2019, 05:09 PM
wes Group: Members Posts: 1,589 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
Ya about 10 minutes, (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/beerchug.gif) Go to settings on your phone. |
Larmo63 |
May 31 2019, 05:15 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Bring those cookies tomorrow morning.
The new Apple OS now shows "insecure" networks. |
Maltese Falcon |
May 31 2019, 05:29 PM
Advanced Member Group: Members Posts: 4,684 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Bring those cookies tomorrow morning. The new Apple OS now shows "insecure" networks. Chocolate chip / macadamia nut goes well with some Speedster Cafe java (IMG:style_emoticons/default/smile.gif) |
jim_hoyland |
May 31 2019, 07:53 PM
Thanks for all the good tips..... (IMG:style_emoticons/default/sad.gif)
trick-e |
May 31 2019, 09:14 PM
Still Learning Group: Members Posts: 115 Joined: 7-July 12 From: Traverse City, MI USA Member No.: 14,644 Region Association: Upper MidWest |
Make sure you have cookies turned on, otherwise we can't track your login. As for the "not secure" message, that's because we don't have a SSL certificate so it deems our login page "not secure". I'll get around to fixing that eventually but it isn't really a big deal. (IMG:style_emoticons/default/shades.gif) I would clarify and add that it’s not a big deal unless one uses the same credentials for another site or account. Don’t do that. If a bad actor gets your credentials to a non-secure site, they will be the first credentials they try to hack your email or banking account with. Make your passwords unique gang. |
SirAndy |
Jun 1 2019, 10:08 AM
I would clarify and add that it’s not a big deal unless one uses the same credentials for another site or account. Don’t do that. If a bad actor gets your credentials to a non-secure site, they will be the first credentials they try to hack your email or banking account with. Make your passwords unique gang. Just to clarify, having a "unsecure" login page on 914world means that someone can theoretically get your 914world password if: - They hacked your computer and intercept your login message. However, at that point they probably already have a key-logger installed, so even if we had a SSL certificate, you'd still be hacked and your password would be compromised. - Your ISPs router(s) are hacked - Our server is hacked That's pretty much it. If none of the above is true, there is no difference between a "secure" login page and a "unsecure" login page. (IMG:style_emoticons/default/shades.gif) PS: Having separate passwords is good advice though. Don't use the same password for 914world and your online banking! |
tazz9924 |
Jun 1 2019, 10:16 AM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Lo-Fi Version | Time is now: 1st June 2024 - 12:08 PM |
