Help me test this 914-6 wiper motor pre-install, Original 914-6 wiper motor |
tailwind22 |
Jun 4 2019, 08:49 AM
Member Group: Members Posts: 89 Joined: 7-November 17 From: Moses Lake, WA Member No.: 21,583 Region Association: Pacific Northwest |
I need to test this original 914-6 wiper motor before installing. Please walk me through how to apply 12v power to test. A picture of the wiring harness is below.
Attached image(s) |
tailwind22 |
Jun 5 2019, 06:55 AM
Anyone???
fixer34 |
Jun 5 2019, 05:14 PM
Senior Member Group: Members Posts: 1,087 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Not sure what/why the red arrow is pointing to.
I believe power and contacts come thru the multi-pin plug. Is the steering column/wiper switch not installed where you can just connect tha cable and try it? |
tailwind22 |
Jun 5 2019, 05:34 PM
Not sure what/why the red arrow is pointing to. I believe power and contacts come thru the multi-pin plug. Is the steering column/wiper switch not installed where you can just connect tha cable and try it? It is a rotisserie resto with the wiring harness somewhat in place but a ways from having power. The picture was noting the proper wiper motor wiring harness for a true 6. |
tailwind22 |
Jun 12 2019, 07:30 AM
OK, I figured this out so will add my solution for future questions. I had my steering column out so I plugged in the wiper switch to the motor harness and applied power to the red wire coming off the harness and grounded the brown lead coming off the harness plus the steering column piece and I had a working motor. This would be unique to a 914-6.
dr914@autoatlanta.com |
Jun 12 2019, 07:31 AM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we still have new factory armatures and brushes on the shelf but no new six wiper motors
914Sixer |
Jun 12 2019, 07:36 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Six wiper motors are unique. Base 911 motor with special wiring harness plug.
Lo-Fi Version | Time is now: 7th June 2024 - 01:20 PM |
